Old 06-29-2004, 07:34 PM   #1
E-brake problem
My Ride: 87 Daytona Pacifica
Hello. I have an 87 Daytona Pacifica 5-spd. The parking break is sort of a necessity for me because my driveway is somewhat slanted and i don't want pressure on the trans. I have adjusted it so it holds on the first few clicks. But because the rear e-break drum is so rusted, it doesn't release so well. I worked some WD-40 in there and it worked well...but when i got it back from the trans shop, after 2 weeks, it froze up again. Is there a better lube than wd-40 for this? any help would be great...thanks in advance
Lee'sdaytona is offline
Old 06-29-2004, 10:32 PM   #2
Hybrid Booster
are you sure you dont have it too tight?? if you cant spin the rear wheel easily with it off, i say its too tight and you should just click it back a little bit and push the pedal farther.
Vigo is offline
Old 06-29-2004, 10:44 PM   #3
I'm sure its not too tight...when i last worked on it, it released real nicely...but after 2 weeks of sitting, it tightened up again...i guess from rust
Old 07-06-2004, 05:50 PM   #4
toooo tight
My Ride: 1987 shelby charger
Engine: 2.2 t1/t2 conversion
my rear brakes on 1987 shelby charger allways lock up when i am going slow they drag....
eef
eef mcglikn is offline
Old 07-06-2004, 05:59 PM   #5
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
the ebrake on my Daytona catches in the sleeve that goes to the drum. The part that brings it through the framerail. I was gonna try some PB blaster in there to free it up. WD-40 didn't work for me either
Mopar_Nutz is offline
Old 07-06-2004, 09:06 PM   #6
My Ride: 88,89,90 Shelby's
Engine: T2's and a VNT
I would work some thicker oil in there.. the wd-40 probably got soaked up.
Turbo Charger is offline
Page generated in 0.13841 seconds with 12 queries
