10-02-2004, 11:30 PM
#17
Originally Posted by Aries_Turbo
Isnt the front bushing the same as the cast arm.... just the rear was different. I thought I remembered reading that. Lemme know if he agrees to make them. I for one would be up for a few sets. I wish someone would make the whole set..... there are so many 89-90 cars out there that would really benefit from a set of bushings.
Brian
PS is there some reason you are switching from your custom control arm bushings or is this for a different car?
Brian, the front bushing on the dual pivot arm is definitely not the same as the cast arm. It is in a metal sleeve and presses into the arm. I switched from the custom arms because I put 91-up knuckles (bolt on brake adapter) on the car for a future big brake upgrade. Since the later knuckle has the ball joint pickup cast 3/4" lower than the 89, my control arm with the longer ball joint stud get pushed down that much more and makes contact with the inside of the wheel. If I had 17" inch wheels it would probablry clear, but i run 16's. I raised the car up a little and can still maintain a nearly paralell control arm angle with the new knuckles.
Firebaron90, that is interesting to hear, it may just clear due to some tolerances, i would like to know how close yours comes, maybe its just my car.
10-03-2004, 10:19 AM
#20
My Ride: Daytona
csracer,
When you were talking about how the knuckles lower the ball joint by 3/4", does that mean that if you lower your car a lot, you can change to these knuckles instead of makeing those special balljoints to keep the control arm flat?
10-03-2004, 12:36 PM
#21
1/4: 13.650
Ok, upon closer look, yes it seems i have the same problem....
the arms are off of a 93 spirit
knuckles and k frame are off the 90 baron....
See this link for the the car before the swap....
http://www.hellafast.com/gallery/vie...the_shadow_018
now notice the shadow with the same arms....
This is distrubing....is this going to clear my 215 45 17's!!!!
Joe
10-03-2004, 05:53 PM
#23
Joe
Joe,
that pic of your shelby is exactly how mine looked, but if i turned the wheel with the car standing still, it would just touch the airdam.
according to the tire calc you will buy a little more than 1/4" more clearance if you swap to the 215 45 17
http://www.miata.net/garage/tirecalc.html
10-04-2004, 10:53 AM
#25
Looked??? what did you do to make it not look like this?? and what is the ball joint modification??? I am using eibachs and konis, so it is kinda lowered???
Joe
I put the stock 89 dual pivot stamped arms back on which centered the wheel again and no more rubbing. I am currently not using the modified ball joint arms. My current setup is 91-up knuckles, R/T adapters and calipers, 11" rotors, 89 shelby daytona stamped dual pivot arms with stock ball joint, stock control arm bushings but the rear one is the HD solid rubber Shelby Daytona piece. I am at the approximate ride height of the MP springs which is about 1-1.25" lower than stock, comparable to eibachs also.
10-13-2004, 09:59 AM
#27
My Ride: Daytonas
Okay So If I hear everone correctly I cannot use the energy suspension bushings on my 89 shelby conrol arms...Damn I guess I'll have to do the ball joints without redueing the bushings
10-13-2004, 10:04 AM
#28
My Ride: Daytona
The way I understand it is that some 89's came with the older style arms, while the majority came with the dual pivot stamped steal arms. Crawl under your car and see which kind you have.
10-13-2004, 03:33 PM
#29
My Ride: Daytonas
http://members.shaw.ca/mydaytona/100_0197.JPG
Can you tell from this pic...I think its the dual pivot.
