Old 10-17-2004, 05:33 PM   #1
Aligning the rear tires on our cars...
1/4: 13.650
Hey all,
I was getting an alignment on my new datona, and I wanted to go all out and have the rear set perfectly, as the tops of my rear wheels seem to sit inward. Well the alignment guy says no problem, until he notices that i have the rear vented discs. He says the parts book lists shimms for the rear drum brakes only. Are the disc shimms different??? If so where can i get some???
joe
firebaron90 is offline
Old 10-17-2004, 06:29 PM   #2
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I just put a couple shims in my 89 Spirit's right rear wheel to reduce toe in fron 3/16" to 1/16". And I gave it a bit of negative camber as well, because it needed it.
I got a pair of shims from my local Chrysler dealer, and they charged me $12 for them. They are 0.010" thick, and according to my newly acquired 1989 factory shop manual, a 0.010" shim will change the wheel alignment by 0.3 degrees.
I don't know about the disc brake cars. My Spirit has rear drums. The disc cars should still have the stub axles, and the shim goes between the axle and the swing arm mounting point.
you don't need to have a mechanic do your alignment. I use a piece of fishing line and a lead weight to figure out what my alignment is. Only thing - you MUST do it on ground that is ABSOLUTLY LEVEL or everything will be wrong.
PS - the shop manual says the acceptable alignment range (on toe in/out) is 5/16" IN to 5/16" OUT !!! That will grind down tires fast! Set your rears to 1/16" toe in. Maybe 1/8" toe in if that's as close as you can get it. Road forces will then flex the axle / wheels just about straight when driving.
Tim_K is offline
Old 10-17-2004, 06:45 PM   #3
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
Hey joe, if the tops of your wheels are tilted inward, thats negative camber I would keep it that way if it's not too radical.
contraption22 is offline
Old 11-10-2004, 11:10 PM   #4
My Ride: 1990 Dodge Spirit
actually mike inward is positive, any alignment angle that tilts away from the vehicle is negative, and towards the "inside" of the vehicle is positive.
CowtownBooster is offline
Old 11-10-2004, 11:22 PM   #5
fyi, you're wrong. negative camber has the top of the tire leaning towards the center of the car.
its too bad they didnt use that system tho, its so simple.. but alas.
Vigo is offline
Old 11-10-2004, 11:30 PM   #6
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
http://www.familycar.com/alignment.htm
LancerShelby is offline
Old 11-11-2004, 02:18 PM   #7
what the hell was i thinking when i wrote my reply... brain fart!
Old 11-11-2004, 03:24 PM   #8
peeyu
ltrain is offline
Old 11-11-2004, 07:09 PM   #9
My Ride: 92 GTC, S2000, GTP
Define radical. My GTS has neg camber after I installed the eibachs, but it looks like it could wear the inner part of the tire faster.
JandHbodies is offline
Old 11-11-2004, 07:51 PM   #10
My Ride: 1991 Daytona Shelby
Engine: 2.5L
Installing different springs in the rear doesnt effect camber. If you are refering to the front, then anything more then -2 is radical for normal use.
Frank
Frank is offline
Mortgage Calculator | Online Loans | Car Loan | Loans | Balance Transfer Credit Cards
Page generated in 0.51735 seconds with 13 queries
