Old 11-11-2004, 10:40 PM   #16
My Ride: The Black Pearl
Originally Posted by shelbyluvinfool
that's all well and good, except you are overlooking the fact that nobody makes a 45 or 40 series 15 in 245!
I think you missed my post where I corrected my error. 225/45-15 is correct. However, it seems that the only tires available in that size are autocross tires.
Kid Doc is offline
Old 11-11-2004, 10:45 PM   #17
Originally Posted by gerber1125
so the bigger the offset, the more room to work with basically?
i checked the tires on my rims now, they are 215/55R15 and they look pretty nice, so ill prob just stick with that size, but i wanted something a little wider and lower profile type but not sure what size to get
No. Bigger offset=less room. Okay, lets take a basic 35mm offset pizza rim 15X6. Now if it were a 40mm offset, the wheel and tire would be 5mm more under the car. If it were only a 30mm offset then the wheel would stick out more. The reason people go to a 38mm offset (Less room/more in) is because you widen the rim by 1". If you didn't change the offset, the wheel would stick out an extra inch and look really ghetto. ~~Heath
Kid Doc is offline
Old 11-11-2004, 11:39 PM   #18
Zed
dont quote me but I think all 15x6 dodge rims are 40mm offset, 15x6.5 SL(lace rims) rims are 35mm offset. Not sure about 6.5" crabs.
Zed is offline
Old 11-12-2004, 03:31 AM   #19
I've used 15"x7" wheels with a 38mm offset and P225/50R15 Tires on my 1987 GLHS. I purchased this wheel & tire combination after seeing Carroll Shelby's own '87 GLHS #0001 with this size on it. Unfortunately, I ended with grooves on my sidewall. It would also hit the inner fenderwells if I hit a bump and I had passenger's in the rear of the car. I ended up rolling the rear fenderwell lip.
Didn't know it at the time, but, Carroll's 'S' had his rear rear fenderwell lip grounded down.
I was able to verify that upon seeing his #0001 car at the Shelby Newport Beach (CA) Auction in 1994. When the car was on display, I ran my hand in the rear fenderwell area and could feel where the metal was removed.
I now use P215/50R15 tires.
scrampage1 is offline
Old 11-12-2004, 08:40 AM   #20
my tires on the SC now are 205/55R15
would i be able to use 215/50R15 on those rims without modifications or problems?
gerber1125 is offline
Old 11-12-2004, 09:58 AM   #21
Originally Posted by wickedshelby
i thought the subies were like 117 x 5 (or some really weird number) i have 205 50 15s on my sc and they fit just right with no rubbing...i dont think i would try to put the 215 on it though...205s are just about the limit at proper tire pressure for spirited driving IMO
are those tires on stock rims, or aftermarket?
if stock, ill prob just stick to the 205/50R15 tires like you are
this is what that kid said about his rims/tires that were on Ebay, the ones i was looking at that were on that WRX
"For sure they will fit any of the Subaru's since the late '80s/early '90s, as
they all share the same hub configuration and have at least similar offset
requirements.
The reason it is a "special" for the WRX, is that the WRX has larger front
brakes. Subaru equips them with 16 inch wheels from the factory, and most 15
inch wheels will not clear the front calipers; these will, just."
Old 11-12-2004, 10:40 AM   #22
It was an example.
Kid Doc is offline
Old 11-14-2004, 06:28 PM   #23
ok how bout this on my stoc SC rim:
does it matter how low a profile you get, or should you stay around 50 series?
i want a lower profile tire, but wasn't sure if it would cause problems if i went to like 40 or 45 series on a 205/15
thanks, Justin
Old 11-15-2004, 12:52 AM   #24
My Ride: '84 GLH, '04 R/T
Engine: 2.2 HO, 2.0 Magnum
I had a set 225/50 kumho ecsta supras on a set of 15''/6.5'' crabs on my 1992 sundance(R.I.P) 2 door. they rubbed a little bit if you turned to lock but the completely changed the handling of the car over the stock 195/60 walmart tires. I could scare the hell out of all my friends in the corners and clover leaf entrance ramps. the only downside(to me) was that with all that rubber the 2.5 n/a would barely chirp second. the day i put the stock tires back on the 'dancer is the day i lost it in a curve, it wouldnt have happened with my kumho's.
vntned is offline
Old 11-15-2004, 01:33 AM   #25
My Ride: 1986 Shelby GLHS
Engine: 2.2l T-2 Commonblock
To clear the air, offset is wheel center line to hub mounting surface. So the higher the # = the further under the car the wheel is located. A 40mm offset puts the wheel centerline in farther than a 35mm offset. I have personally run both 225/50/15 and 225/45/15 on 15x7's with a 38mm offset. Only thing, the 225/50's did I have a slight problem rubbing the rear fender before I rolled the lip(but autocross tires usually are a bit wider than specified). FWIW, Johnny Spiva used to run 15x8's on the front of his glhs for autocross.
Another thing, don't just go by the number the tire has on its sidewall. My 205/50/15 Azenis are as wide as the 225/50/15 street tires my friend put on his daytona.
glh-s-car-go is offline
Myspace Comments | Web Development | Synchronization fast and easy | MPAA | Online Loans
Page generated in 0.39989 seconds with 13 queries
