11-09-2004, 08:26 PM
My Ride: 1988 Dodge Daytona
Engine: 1988 2.2L Turbo II
Originally Posted by gerber1125
is that the widest tire you can go on a stock SC rim, 225/45-15, or is it smaller?
i am getting new tires for my SC, and wanted to know the widest tires i could get for my 5-lug SC rims without doing any bending of the fenders
I wouldn't suggest putting a 225mm width tire on a SC wheel, which I believe is probably 6" wide. It might give you some more traction in a straight line, but the car will not corner very well. I would suggest a 205 or 215 width tire unless you get some wider wheels.
11-09-2004, 08:34 PM
My Ride: Dodge Omni GLH clone
Engine: 2.2 inline 4
I used dean's old 225/50/15's and they rubbed the lips on the rear wheelwells, on 6" polished pizza wheels.
I now have 205/40/17, on a 7.5" wide wheels, with 38 mm offset...just for comparison's sake. they do rub up inside the rear wheelwells with 2 people in back seat over big bumps, and I can barely pass a baby inger between the tire and spring perch on the strut in front.
11-10-2004, 08:58 AM
If you go to the tire manufacturer's website they should list specs on what wheel size a particular tire should go on as well as a maximum and minimum width. I would try to stick with the recommended width.
11-10-2004, 10:20 PM
#12
My Ride: The Black Pearl
would 15x7, 35mm offset, and 5x100 mounting rims with 225/45-15 wheels fit my SC? Some kid is selling Revolution wheels that he had on his WRX and those are the specs, just wondering if those would fit or not
lmk, Justin
ebay auction # is 7933797266 if you wanna look at them
No, The MAX on a L body without serious modification is 15X7 wheel, 38mm offset and as wide as 225/45-15 tire. As I understand it the 38mm offset is the distance from the rim (Inner) to where the hub attaches. If you went 35mm it woudl basically push the wheel out another 3mm, not a lot, but more than enough to cause you problems with a wide tire. ~~Heath
