12-06-2004, 12:35 AM
Questions before converting GLHS over to 4 wheel discs
Garrett Booster
My Ride: Shelbys or Cummins
What size are my GLHS front discs now?
I have 87 & 88 Shelby Z Daytonas. What size are these front and rear?
If I convert the GLHS now using the hardware from the Daytonas then decide later to upgarade to larger rotors from say a 89 Shelby Daytona, will I need to change the knuckles and spindles again or will the rotors and calipers go on with no other mods?
Thanks,
Kurt
87 GLHS #775 SOLD
87 GLHS #950 SOLD
87 CSX # 108 105,000 miles
92 W250 ext. cab Cummins 5 spd 38 psi 455hp/1005trq 13.34 @ 102 @ 5800 ft www.turbodieselregister.com
02-01-2005, 06:55 PM
My Ride: 1985 Omni GLH Turbo
Engine: 2.2 TI
Excellent timing, I was just thinking about brake upgrades...
How much of an improvement are people seeing with the (solid) rear disc conversion? Is it a dramatic improvement in stopping distance and feel, or is it just the cool thing to do? Same with the 60mm caliper upgrade.
I have an 85 GLHT, for comparison purposes. I'm trying to do a budget buildup, so I'm debating if this is worth the coinage.
Does anyone have the rear disc setup for sale?
Thanks!
02-02-2005, 05:38 PM
4 Wd Brake Upgrade
My Ride: 1985 S/C
Engine: 2.2 turbo 2
The pedal feel and response is night and day, with the 4wdisc compared to the disc,drum setup. if you drive one with it you will never want your drum brakes back. Shawn
02-03-2005, 09:07 AM
My Ride: 1985 S/C
Engine: 2.2 turbo 2
Hey Eric I used the e-brake cables that were on my car with the drum brakes,the cables went right in. Shawn
Originally Posted by shelbyluvinfool
Shawn, what did you do for the e brake again? I'm ready to swap ASAP, as I need to do the brakes anyway, so might as well do them right!
02-04-2005, 12:06 AM
#12
My Ride: '87 Omni
Engine: Dodge 2.2
I have a severe dislike for my 220 rear drums I put on my omni. The car doesn't weigh enough to seat the shoes properly. I ended up having to removed the shoes, place them inside the drum and then clearance them with a die grinder to get contact anywhere besides the corners of the shoe. Dumb brakes just suck hehe... Notice no new carmaker uses them unless its their bottom bottom dollar car?
