so.....my 94 shadow has 4 wheel disc brakes with ABS.
anyway.....there's a problem with my adapter/bridge/bracket whatyamacallit. (i call it the rear caliper adapter while everyone else calls it something else.)
my pads are locked in place and will not slide correctly. do not tell me what the problem is because it will not fix the problem (i've allready had a few professional technicians attempt to advise me what my REAL problem is when i allready knew the problem in the first place until i actually let them check my car). calipers are in perfect working order.
the reason my pads are locked in place IS because the bracket/adapter/whatyamacallit has pits gouged into it by the pad. the pads cannot slide parallel to the rotors and are now locked in place and are wearing crooked.
i only have 3 options to fix this problem so that my rear disc brakes can finally work correctly. this is in order of expense, most costly is stated first. i will need to purchase brand new pads, so that is a given expense.
option #1: purchase brand new adapters;
adapters are not available at auto parts stores like NAPA or murrays, etc... they are only available at the dealership. i am able to get employee pricing on the adapters for around 140 dollars EACH. i am in need of a PAIR.
con: i'm broke and can't really spend 280 bucks for 2 adapters. unless my safety isn't worth 280 bucks?
would need to complete a full tear down and rebuild of the rear bearing assembly.
pro: these are BRAND new chrysler specific parts that are guaranteed to work without fitment problems, less headaches. would need to complete a full tear down and rebuild of the rear bearing assembly.
Option #2: salvage yard hopping;
rear disc brakes were optional on these cars and i'm kind of concerned about the availability of them being found in the yards. what are the chances of me actually finding a shadow/interchangeable vehicle with rear disc brakes? on top of that, what are the chances of them actually still working? and on top of that with ABS? (i don't know if there's any real differences in ABS or non-ABS adapters.)
con: time consuming in search of a pair. at this time of the year it's too damn cold to be walking around in yards. too cold to pull these parts myself, especially without either having a bolt too rusted out, having to use a jack to remove the wheels (if need be) and finding a pair that is still in good working condition. in general, just even finding a good pair. would need to complete a full tear down and rebuild of the rear bearing assembly.
pro: least expensive than the first option, depending on what the yards are asking for them, but most likely less expensive. would need to complete a full tear down and rebuild of the rear bearing assembly.
Option #3: fill up the holes with a tack welder;
i was told that since the adapters are cast iron that i could tack up the holes on the adapters and then die grind/file the surfaces back down till they're flat. would need to find/determine what kinda of tack welder to use. i will not need to remove the adpater from the vehicle.
con: none that i can think of, except of possibly burning stuff like the brake lines.
may need to complete a full tear down and rebuild of the rear bearing assembly if the adapter gets too hot from welding (very unlikely).
pro: seems a bit too easy. may need to complete a full tear down and rebuild of the rear bearing assembly if the adapter gets too hot from welding (very unlikely). least time consuming of all options.
unless i could find someone here that's selling their adapters? i think they'd rather save their's for their conversion or something.
thanks.
