Originally Posted by skippyman87
I was just wondering what the best suspension setup for an 86 daytona would be as far as better control and lowering. I want to drop whole car 1 inch or more.
Derek
Derek, do you want best, or just better?
When it comes to suspension you can go from mild to extremely wild with just about any car. Let's look at it in components:
Bushings: Best bet here is to replace every factory black bushing with a polyurethane bushing. Look for quickor or suspension techniques.
Springs: Here you can go from mild Eibach just for lowering and slightly improved handling, to wild custom rate coilovers that can let you adjust ride height as well as finely tune the suspension and weight distribution of the car.
Struts/shocks: Easy as Monroe, good with KYB, Better with Stock Konis, and best with custom double adjustable koni's.
Add Ons: There are many add ons out there for these cars including bigger sway bars, strut tower bars, Panhard bars, camber plates, and even as mentioned full K frame swaps.
It really depends on what you want from your suspension. I woudl expect to spend a minimum of $500 and a maximum.... well. $4000 is a fair number for a cheap race suspension. ~~Heath
