Old 01-27-2005, 05:33 PM   #1
2 inch drop and aligment?
will i be able to get a good aligment if i drop my car 2 inches or more?
mopar3.0 is offline
Old 01-27-2005, 08:14 PM   #2
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
yep
Garret is offline
Old 01-27-2005, 09:37 PM   #3
My Ride: 85 GLHT, 87 ShelbyZ
But the suspension Geometry will suck as the axles will be out of proper alignment and bumpsteer will increase. You don't want the lower control arms any farther than parrallel to the ground.
GLHNSLHT2 is offline
Old 01-27-2005, 09:42 PM   #4
Engine: 2.5 16v
well I assumed if he wanted to drop it 2 inches it wasn't for handling
Garret is offline
Old 01-30-2005, 07:50 PM   #5
Would look nice
I dont know if you would have geometry problems, but i know it would look really sweet with a nice oversized set of rims on there and a 2 inch drop..
Where are you getting springs that will drop it that low? You cutting lowering springs?
Tryte is offline
Old 01-31-2005, 08:14 PM   #6
My Ride: 87 Shelby CSX #400
Engine: 2.2 turbo 2
on most cars you don't want to lower them much more than 1 inch... any more and you will change the geomitry to the point it will handle worse....
you'll look really cool and fly with your car off the road in a ditch because you reduced your efective contact patch under compresion in a corner...
not every idea AutoZone sells to ricers is good for performance.
HYDCSX400 is offline
Ringtones | Debt | Jordan Retro | Loans | Credit Reports
Page generated in 0.28166 seconds with 13 queries
