01-31-2005, 05:52 PM
Mr. Stink Bug
Originally Posted by hudsons7x
I did install the perches correctly however the car still sits to high in the rear. Is there anyway to lower it without sacrificing ride quality? So there is no such thing as a 4 door "Charger" right? I guess I could get stock shocks and sell the KYB's on ebay, I paid $30.00 each for them, think I could get my money back?
supercrackerbox wrote: Sure they did. It was called an Omni. The two cars had the same chassis, with the exception of the rear shock mounts. If you put rear shocks spec'd for an Omni onto a Charger, it will sit higher in the rear.
Like supercrackerbox tried to explain to you. The Charger and the Omni are both built on the same platform or chassis. They are "L" bodies. They look different, the Charger has two doors and the omni has four doors. It sounds like you have shocks for the four door "L" body or Omni on your two door Charger. This is a common mistake, you are not the first one, and I doubt you will be the last.
Joe Dzwil
