01-30-2005, 12:53 AM
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
Originally Posted by RockitZ
Also, I noticed that is seemed like everything else connected to the wheel, i.e. strut etc. moved along with the wheel when grasping it from side to side.
if that's the case...
Originally Posted by MONK
sounds like an inner or outer tie rod, possible ball joint. if you still have movement side to side when it is on the ground, it is probably the inner tie rod. jacked up, if you push on the left front of the wheel, about 7 or 8 o'clock and it moves, most likely a ball joint, if it seems to move when you hold it on both sides, 9 and 3, probably outer tie rod, also, you can reach around and feel the outer tie rod move when you shake it with the other hand. hope this helps, good luck!
^^^what he said.
