Old 02-06-2005, 01:32 AM   #1
18" by 8" with 35mm offset work on Shadow?
Will an 18" by 8" wheel work on a Shadow with a 35mm offset? I don't want any rub, or *very* slight rub at full lock. But want to get some big wheels and tires in there.
1985ShlbyChrger is offline
Old 02-06-2005, 10:42 AM   #2
You would have to run a real short sidewall tire, but it should fit. I have 17 x 8 on my Daytona, and the 245-40s are about the most I can fit. If I had 45 series tires, they would rub. I think Shadow16v has 18 x 8s on his Shadow, maybe he'll chime in.
curbman68 is offline
Old 02-06-2005, 11:06 PM   #3
My Ride: Lancer Shelby
Engine: 2.5T
it would stick out in front unless you modified the fenders i have 18x7.5's and they stick out a bit too much for my liking. I'm probably going to cut and flare the fender just a hair to tuck them in a bit. It should be interesting, even though i know bodywork ive never flared anything yet.
Mystryguy is offline
Old 02-07-2005, 12:28 AM   #4
My Ride: 85 GLHT, 87 ShelbyZ
If the offset is correct they shouldn't stick out anymore than 225/50 15's on Crabs or Fiberriddes or any of the other 6.5" stock wheels. They also shoudn't rub if it's a 225 with the right size sidewall to make the overall height the same as as 225/50 15
GLHNSLHT2 is offline
Old 02-07-2005, 02:53 PM   #5
My Ride: 93 Dodge Shadow R/T
Engine: 2.2 DOHC Lotus
I am running 18X8 on my Shadow with a 225-35-18 tire. Fit great with no more rubbing than a 225 on a stock wheel.
Shadow16V is offline
Old 02-07-2005, 02:54 PM   #6
Forgot to mention, they are a 35mm offset as well.
Old 02-07-2005, 03:12 PM   #7
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
What's the point of an 8" wide rim if your only going to run 225's on it? I've stuffed 225's onto a 6" wide rim.. I'd run like 265's or bigger on 8" rims.. heh..
Una is offline
Old 02-07-2005, 04:07 PM   #8
Ben, do you have any pictures of the wheels on the car? I'd like to see what they look like.
Webbdesign | Free Online Games | Secured Loans | Loans | Credit Cards UK
Page generated in 0.38863 seconds with 13 queries
