Old 02-08-2005, 11:51 AM   #1
minivan strut bar ?'s
My Ride: 91 R/T-66 pontiac
Engine: T3 2.2/ 4bbl 389BB
1/4: 13.940
i know they dont make one for a mini, but the bolt pattern for the struts and the bars from a daytona are the same right?
so i could buy a bar for a tona, cut it, extend it and bolt it right up?
glht_omni is offline
Old 02-08-2005, 11:16 PM   #2
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
I don't think the pattern is the same, but you could certainly fab the ends. I've heard that the bar for a Lexus ES series car is exactly the right size, but you'd need new brackets. It might be easier to just go ahead and fab your own though.
Avenger is offline
Old 02-08-2005, 11:41 PM   #3
1/4: 13.940
daytona and mini strut bolt patterns should be the same, cause people lower their minis with daytona struts.
right????
Old 02-09-2005, 12:20 AM   #4
Engine: 135 CI
If the distance between the strut towers on a Daytona and Mini are the same, then you shouldn't have a problem. If the bolts are different (which they shouldn't) then you could just weld the strut tower bar brackets directly to the strut towers or just simply drill new holes.
A cheaper route is the neon strut tower bars which can be had for $6 on ebay.
Mario_Boost is offline
Old 02-09-2005, 01:44 AM   #5
1/4: 13.940
thats what i am hoping- that the 3 bolts on a daytona tower are the same pattern as a mini so i can cut, add, and weld the bar to make it longer.
whats the deal with the neon bar? 93-98 or 99+ style?
is the bolt pattern the same as a mini? or slightly off?
Old 02-09-2005, 08:54 AM   #6
Engine: 135 CI
Old 02-09-2005, 06:05 PM   #7
1/4: 13.940
mario is it the same or do you have to oblong the holes?
Old 02-12-2005, 09:10 AM   #8
On my '91 Voyager it looks like the windshield washer reservoir would get in the way of most strut tower bars...
On the neon bar, I have read that you have to redrill the plates...
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 02-15-2005, 01:23 PM   #9
My Ride: '88 Shelby Z TII
The distance between the towers is also greater. I've been told that a bar for a 240SX usually has enough adjustment to make up for it though...
Reaper1 is offline
Old 02-15-2005, 04:35 PM   #10
1/4: 13.940
any specific year 240sx?
Old 02-15-2005, 07:00 PM   #11
Not that I know of, but you will have to modify the mounts, I know that one for sure...
Reaper1 is offline
Old 02-15-2005, 07:11 PM   #12
If you into fabbing, I used a 93 Cavalier strut bar. Cut it in the middle, got some larger square tube metal and welded that up. One of the 2 strut holes lined up, removed the unnecessary one and made 2 more. All in all, took me an hour to redo. Well worth the effort and it clears everything.
Get mysqli last insert id | Credit Cards | Home Loan | Loans | Buy Anything On eBay
Page generated in 0.38689 seconds with 13 queries
