02-08-2005, 09:03 PM
My Ride: 88 sundance
take the front spring strut assy out fo the car, use a compressor to squeeze the spring together, take the top nut of slowly release pressure on the spring, i uasully cut the top of the spring, just go straight down from where the coil stops, or as close as possible, thats one wrap, or might need to one and a half as uasully there is a dead wrap(spring is flattened against the coil under it) and use a cut off tool and grind away, or a angle grinder if u need. Put it all back together. Ive have good successs upgrading to monroe sensatracs or similar with cut springs so u might wann pickem up. on the back take off the shocks, support the axle with a jack and jack it up a little might have to take off the panhard bar or sway bar. Let the jack down slowly and th e coils will fall out, repeat same as front. on the back if the wraps are spaced farther apart might wanna try goin half at a time. but remember the suspension will settle a little over night. If u cut the rear though be careful of using air shocks if u pump them up too much and hit a big bump the spring could fall out, but with only an inch worth of cutting shouldnt be a problem.
