02-13-2005, 01:30 AM
Which Brakes? Which Car?
My Ride: Convertible Turbo K!
Does anybody have the information as to which brake systems came on which cars? I'm aware that 88+ Turbo II cars have 11" brakes and the vented rears, and that R/Ts do as well... not that parts cars of those models are easy to find. I also know that all cars have 4-wheel discs of some sort or another after 1988. I know about the "SLH" packages using the minivan brakes. That's all I can find on the internet.
Is there a big table somewhere that I'm missing that shows which brakes came on which model/year pairs? If there isn't, then start posting the info up from your FSMs and I'll compile it myself!
I'd love to swap the car over to 11" brakes, but it's hard to do when I can't find the information.  It'd be awesome to help create a resource that would be useful for quite a while to come.
02-13-2005, 03:10 PM
My Ride: 1986 Shelby Charger
Engine: 2.2 pseudo TII
02-13-2005, 04:30 PM
:-) Are the minivan brakes more powerful than the 11" ShelbyZ-R/T brakes? Are they significantly more powerful than the 10.25" brakes that come on everything after 1988? Where else can I find 11" brakes?
Thankyou!
02-13-2005, 04:34 PM
My Ride: '85 GLH
I think the main purpose to the mini-van brakes is the "improved?" cooling - more vanes on the disc. As well as the beefier (thicker) rotors so you lessen the chance of warping them. Also you won't have to replace them as often!
Later,
Craig
02-14-2005, 12:52 AM
Originally Posted by capev86
the early 90's dynasty chassis cars have the 60mm/10-1/4" setup only the rotors are the standard thickness and the calipers are the dual pin setup like instead of the single pin like the van brakes. dynasty will also have the van/4 disc car 24mm master cylinder
1989 Spirit ES 2.5 T1
dynasty front brakes and m/c
90 spirit es solid rear disc and prop valve
(i will be able to use 14" wheels as spares)
Mmm. Awesome. This is most helpful--the 90s Dynastys have the same brakes, basically, as the minivans, as well as the 24mm MC.
I'd really love to just swipe the brakes off of a Spirit R/T, from the MC to the calipers, should I ever find one; I'll just be looking for the Dynasty brakes until then. I'll be driving the car just about every day, but I'd like to drive the hell out of it sometimes, too.
02-14-2005, 04:05 AM
For those following along from home, I re-found a page I had already seen that has just about every question I was wondering about : http://minimopar.knizefamily.net/perf/brakes.html
Thanks for your awesome input!
02-15-2005, 01:28 PM
My Ride: '88 Shelby Z TII
I have a set of rear calipers off of a '91 Y-body that have 36mm pistons in them(the same as 11" brake set-up), but used solid 10.25" rotors and drum style e-brake....It worked VERY well with the minivan front brakes...
02-18-2005, 12:39 PM
The Y-body rear 36mm disc set-up requires modification to the adapter plate(the holes for the spindle are farther apart). The spacing for the caliper to adapter plate is different than the 11" set-up, and is also different than the regular solid disc caliper(due to the larger housing for the larger piston). Whether it will fit 14" wheels or not...I really don't know. I had 16's on the car the whole time and the car in the yard didn't have wheels on it IIRC. They "might" clear, but a test fit would be required.
Another rear brake set-up that nobody has mentioned is the AWD Minivan set-up. They have discs too, but they require the larger bolt pattern and possibly other things to make it work right. I've never really messed with one in person...
02-21-2005, 12:22 PM
#13
All I know is what the set-up came off of. It was definatly a New Yorker...
