Old 02-18-2005, 09:50 PM   #1
Do I need wheel spacers?
since i got eggshells from the junkyard, the tires have been rubbing on the rails and the inner splash guards. the tires that are on the wheels are P205\60\15. should i use wheel spacers or go with P205\55\15 tires?
bmxrider is offline
Old 02-19-2005, 01:13 AM   #2
I'm guessing on the LeBaron? 205/60's should be stock, or darn close. Unless it's rubbing severely, I wouldn't worry about it. Most of the cars rubbed lightly from the factory, they called it "friendly interference" I believe. Can you actually hear/feel it, or are you just seeing the marks in the wheel wells?
supercrackerbox is offline
Old 02-19-2005, 01:17 AM   #3
i am feeling rubbing inside the car. wear the tire rubs on the rails, i can see bear metal. also, on the driver side, the plash guard has marks and it also hits the tranny side cover.
bmxrider is offline
Old 02-20-2005, 05:10 PM   #4
bump, i will probably sell my eggshells w\ good rubber. KEEP AN EYE OUT.
bmxrider is offline
Old 02-20-2005, 05:18 PM   #5
My Ride: 84 600 convertible
Engine: 2.2 T1
195/60r15 was stock on the pizza wheels on the E-class Lebaron. The offset might not be correct on the later wheels, so spaceres may be needed.
Hemi-K is offline
Old 02-20-2005, 05:36 PM   #6
cut the centers out of old break rotors , seen it done before not sure about safety
mopar3.0 is offline
Old 02-20-2005, 10:02 PM   #7
i saw a good pair of pizzas on a turbo z in the junkyard the other day, they had 205\60\15 and im thinking that it still rub. also saw laced wheels and they had 205\60\15 too. i would like to have a nice set of stock chrysler wheels and ever since the eggshells rub, i dont think i can go a bigger size.
bmxrider is offline
Old 02-20-2005, 10:28 PM   #8
Ok, bottom line, all the stock 15" Chryco wheels were the same dimensions. The CS/Shelby Crabs, CSS, LeMans, and Fiberide wheels were a half inch wider, but the backspacing was the same. If it's rubbing that badly, you need to have your front end checked out.
Old 02-20-2005, 10:38 PM   #9
they only rub when i cut tight, like making a u-turn. sorry, i should of explained my situation better when i posted this thread.
bmxrider is offline
Old 02-22-2005, 12:27 AM   #10
Bump
bmxrider is offline
Old 02-22-2005, 01:13 AM   #11
My Ride: 85 TRiz, 89 CSX #414
Engine: 2.2 NA, 2.2 TIV
It;s typical for rims to rub like that. I installed 15" pizzas on the turismo and for a while I was curious as to why my inner splash guards had black marks on them. It was because of cutting the wheel too sharp, as well as having blown out shocks and struts. I had 195/50/r-15's on and they still did this. It's just a thing you have to watch out for, and I just try to not take turns so sharp anymore or steer real hard to the right or left. I assume that once I install my KONI's in the summer and do some lowering with the coilover setup that it's going to even be worse, but if I have to I may switch to a 40 tire.
DC Turismo is offline
Old 02-22-2005, 11:59 PM   #12
from the way it hits and rubs, i get the feeling for not putting them on. it just doesnt look right. from talking to a friend, i'll be putting the eggshells back on. i guess a lil rub wont hurt the tires or car.
bmxrider is offline
New Cars | Internet Advertising | Credit Cards | Balance Transfer Credit Cards | New Cars
Page generated in 0.38095 seconds with 13 queries
