02-22-2005, 09:45 PM
#13
My Ride: '87 Omni
Engine: Dodge 2.2
Yes, it is a tapered fit to the hole in the knuckle, If you hit the side of the knuckle as if you were trying to hit the taper itself, it will pop out. You will have to hit it fairly hard with a moderate sized hammer for this to work. Once you master it, you will never used the special tool again, its just not worth it, unless you're trying to protect the paint or something.
