Old 02-19-2005, 08:14 PM   #1
converting a neon to 5-lug
Mo' valves, mo' boost
jonnymopar's Avatar
My Ride: Daytona ES
Engine: 2.4L DOHC
I've got a chance to pick up a 95 Neon with next to nothing for miles. My poor Daytona has a ton of miles on it, cancer all over it, needs an exhaust, a windshield, tires, piston rings BADLY, and you have to shift it with two hands when its less than 25 degrees outside. It's gonna murder me to get rid of it, but life goes on.
My question is... what's involved in converting a 4-lug Neon to 5-lug? Just spindles? Entire suspension system? Not worth it? I ask because I've got a set of snowflakes with good tires that I'd use if I could. Probably won't look right, but I'll do anything to get it to handle better than it does now. I've heard they handle excellent with the right wheels. I test drove it and the car is way punchy compared to a big heavy TBI Daytona, but you can't even put the power to the ground with those 13" tires!
*OR* is the bolt pattern from the early Daytona/Laser rims the same as the 4-lug Neon?
Jon J.
1989 Daytona ES 2.4L - MPH (and, turns out, MPG too!!)
2003 Neon SXT - MPG... yeah just MPG
jonnymopar is offline
Old 02-19-2005, 10:34 PM   #2
id guess its the old 4 on 100 pattern. the 5 lug is the 5 on 100 mm setup on both the neon and our older fwd's. neon and pt cruiser share the old smaller 5 lug pattern. early 90's+ grand caravans, all newer caravans, any year intrepid, etc all use the wider lug spacing.
note: pizza rims won't clear the calipers on the pt cruiser even though the brakes are only 10-1/4" rotor i believe. i tried and it won't work, sorry, you'll need bigger or newer rims to fit!
capev86 is offline
Old 02-19-2005, 10:49 PM   #3
Neon wheels
My Ride: All of them
Engine: 2.1 T1
Check this link and it will tell you about Neon 4 bolt pattern wheels. Apparently they are the same as early 4 bolt.
http://www.neons.org/faq/faq/FAQ_S.html#OEM%20Tires
mike mckay is offline
Old 02-20-2005, 09:53 AM   #4
My Ride: 84 600 convertible
Engine: 2.2 T1
To be honest its probably more work than its worth. You'd have to change the knuckle, hub, rotor, caliper bracket, calipers, pads, and thats just the front! The rear drum/hub has to be changed too. I'm not 100% sure but I think the base models with the 4-lug used smaller rear brakes than the 5-lug. If this is true, then you'll have to change the backing plate, shoes, hardware, etc.
The bolt pattern is 4X100mm.....quite common. You shouldn't have any trouble finding wheels for that pattern as both Honda and VW used it for a long time as well as Mopar.
Hemi-K is offline
Secured Loans | Debt Help | Myspace Layouts | Blog Forum | Car Loan
Page generated in 0.31148 seconds with 13 queries
