Old 02-20-2005, 02:52 PM   #1
Dynasty suspension and brake parts. what can i use on my sundance?
My Ride: 1987 Sundance
Engine: 2.2L T2
i just picked up a 3.3L Dynasty. I plan on using the MC and the front brakes as an upgrade on my sundance. Is there anything else I can use from the Dynasty, swaybar, springs..? i was thinking possibly if the dynasty came with stiffer springs i could use those and cut them to lower my car without the worry of it bottoming out. anybody done anything like this?
TURBO_DANCE is offline
Old 02-20-2005, 03:46 PM   #2
swap the rear springs - more cargo capacity, also stiffer. if the the dynasty has the newer k frame and your shadow does not, swap 'em! newer knuckles have bolt in bearings (instead of press in). obviously the front brakes and m/c. stay away from the prop vavle on these cars - not aggressive enough for anything smaller than a C body. grab the 15" space saver!!!
other obvious items - fuses, bulbs, extra chassis fasteners, spare wheels, steering wheel (color), cruise control equipment?, low mileage parts worth saving that will swap like shocks, etc, etc, etc....
capev86 is offline
Old 02-20-2005, 05:50 PM   #3
My Ride: Voyager
Engine: 2.5 .040 over cast
i dunno about those rear springs man, 3 people sitting on the trunk of my dynasty and it bottoms out...The shocks are fine and there is only 85k on the car.
myplasticegg is offline
Old 02-21-2005, 02:05 AM   #4
Engine: 2.2L T2
a dynasty is also a heavier car, so using them in my car they would be stiffer.
Old 02-21-2005, 03:10 AM   #5
My Ride: Convertible Turbo K!
Beware-I'm pretty sure the Dynasty/Imperial/N'Yorker K-Frame/Arms are the ones that are a little bit different and cause people to regret thinking about the k-frame upgrade in the first place. Double check compatibility before using that Dynasty K-Frame
TylerEss is offline
Old 02-23-2005, 10:13 PM   #6
Engine: 2.2L T2
i didnt plan on goin that far anyway, ill leave the k frame alone. thanks
Mortgage Calculator | Mobile Phones | Personal Loans | Mobile Phone | Mortgages
Page generated in 0.33246 seconds with 13 queries
