02-21-2005, 04:45 PM
Tire size quesstion...
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Ok.. I just ordered up a set of 16x7 rims for my Daytona. This car came stock with 205/60-15's on it, on 15x6 of course. My math shows that tire to have a 627mm diameter. And it's obviously 205mm wide (8.07"). Now, the tires I WANt to put on the new rims.. 245/45-16's. That would give a diameter of 626.5mm.. REALLY close to stock! But that's an extra 40mm of width when the rim is only 25mm wider.. Am I asking too much of the new rims? I've stuck 225's on the stock rims before.. I'm just trying to get some wide paws on this car for cheap..
02-21-2005, 04:53 PM
My Ride: 88 sundance
a 7" wide rim would be plenty good to accept a 245 tire, as lon as u dont have rubbing issues
02-21-2005, 04:57 PM
My Ride: 1987 Shelby GLHS 189
Brian, Reeves has been running 245's on 6.5" crabs on his 88 daytona for years. I believe they are 245/50/15's.
02-21-2005, 08:07 PM
Engine: 2.5L Turbo
I'm not going for handling/cornering. I'm going for traction in a straight line.
02-21-2005, 09:48 PM
i think 245 would be ok, bein such a low profile there isnt gonna be alot of sidewall roll anyway, i can tell ya alot of new trucks and jeeps have 245's on rims no wider than 7". i think i seen a beamer with 245 45's or 40's roll through the shop the other day, if its done from the factory then it has to be ok, what size do srt4's run? i think those rims are 7's or maybe even 6.5's.
02-21-2005, 10:20 PM
Engine: 2.5L Turbo
SRT4's come stock with 6" wide rims, continuing a long TD tradition.. hahaha..
02-24-2005, 09:31 AM
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
be careful not to over-generalize and conclude that since some factory offering had a 245 on a 7, that its OK... or that you have seen or heard people running 245s on 7s .. so it must be OK
the other major factor here is that profile of the tire !! the proper rim width (range) for a 245/75-16 is different for a 245/45-16
follow csracer's advice - check out tirerack.com or the manufacturers website(s) , each tire size has recommended rim widths.. if you go to the wider end of the recommended, you will have quicker steering and little worse ride; if you go to the skinnier end of recommended, you get little better ride and little slower steering..
similarly, if you mount your tire on the skinniest of the recommended, you may see quicker wear to the centre of the tire; if you mount it on the widest, you may see quicker wear on the outer portions of the tread
02-24-2005, 10:11 AM
just checked my bfg book and it said 245/45r17 7.5-9" wide rim
02-24-2005, 01:21 PM
Engine: 2.5L Turbo
Yeah, I'm just gunna toss 225/50's on these 16x7 rims.. Thanks guys. Cheaper rubber at that size anyways.
02-24-2005, 03:27 PM
My Ride: 86 GLHS
Engine: 2.2 Turbo Intercool
Don't go too cheap, if anything, these cars need the stickiest rubber possible.
02-24-2005, 09:00 PM
#12
My Ride: 87 GLHS
Actually low profiles make it worse because they don' thave any room to buldge over the width of the rim.
My 205/45/16 Sumitomo HRZII tires actually say "don't mount on 6.5" rims" right on the tire.
-Rich
