04-15-2005, 10:50 AM
Brake upgrade for 90 caravan
My Ride: 89 caravan
Engine: 2.5 TurboI
Has anybody upgraded the brakes on thier turbo van?
04-15-2005, 12:03 PM
Search in this forum, I just covered it in great detail,
Originally Posted by The Pope
all 89Shelby Daytona or Spirit R/T, 11" 4 wheel vented disk brakes. Buy the front and rear brakes, then the pro valve and master cylinder. Its all a bolt on, just readjust your ebrake when done. Piece of cake.
That is partially true but no rear discs bolt on mini's, and if the knuckles are off stamped control arms, then they fit.
If your want more stopping power, put on a 90 B150 M/C, I just did that and the brakes are much sharper.
04-22-2005, 12:38 PM
My Ride: 89 caravan
Engine: 2.5 TurboI
Simon, this M/C is good with the stock brake setup?
04-22-2005, 12:58 PM
Yep, its awesome!
Let me search for the part# and I'll post it in a bit!
Ok, found it, used Raybestos #39862
You also need to go to a parts store and get a couple of brass adapters for the brake lines as there larger and this way, you don't need to cut anything.
Make sure to properly bench bleed the cylinder!
04-23-2005, 09:54 AM
My Ride: 89 caravan
Engine: 2.5 TurboI
Thanks, when I am ready I will get one. Upgrade parts for 3 cars at once is a challenge sometimes.
05-01-2005, 01:21 AM
Originally Posted by Richard Paul
The 89 vans had optional 11" brakes. They look the same as the same vintage daytona brakes but the knuckle is slightly different on a minivan vs a car.
You will also find all minivans with big brakes have big bolt pattern too, so a hub change is called for. Minivans with big brakes have 15" wheels.
I have 2 local friends using mini van knuckles, brackets and calipers with small bolt pattern bearing spindles and rotors on Daytonas. Maybe your taking the second gen mini?
05-02-2005, 12:37 PM
#12
The M/C worked awesome,
I just got a 2nd Gen K-member and Johnny's bushings, then can install the knuckles and 11inch setup!
