04-29-2005, 11:00 PM
back in the old MP catalog was a Daytona RWD conversion K-frame. you may want to do some digging to find that pattern. If it was me, I would figure out a way to work around or modify the front K-member.... like you could try to see how things fit as it sits, modify oil pan, fabricate your own motor mounts, trans cross member, etc... if the k frame poses a problem, leave it bolted in, take out the rack, cut out the center of the k-frame, then modify as needed. Heck I've done A LOT of odd conversions over the years, there is NOTHING you can't do with a torch, sawz-all, welder, some steel and a little creativity... Like I installed a 2300 ford engine into a Vega chassis, a Buick Nail head into a 52 ford, a Dodge Aries rear axle assembly into a Pontiac grand am, 289 into a pinto wagon... and much much more.
I would, however, remove the heavy 8 3/4 rear end and go with a ford 8" if you are doing a 4cyl turbo setup. the 8" is quite a bit lighter, has LOTS of gear ratios and way cheaper parts. you can have custom axles made (or do it yourself) to have the same 100mm bolt pattern on all 4 corners. just install the outer CV joint into the front spindles. do a low cost coil over conversion on the front like I described numberous times
