Old 05-01-2005, 10:30 PM   #1
L Body Sway bar bolts HELP PLEASE
My Ride: shelby charger
Engine: 2.2T
Hey I have a broken sway bar bolt righht under the stearing rack how can I fix this without to much trouble it has an aufull vibration thanx drew.
glhsdrew is offline
Old 05-02-2005, 12:01 AM   #2
If there is enough of the broken bolt sticking out, heat it up untill it starts to turn red and try to thread it out with some Vicegrips. If it broke off flush with the crossmember, you'll have to drill it out.
-Chuck James
Stevien1 is offline
Old 05-02-2005, 11:04 AM   #3
Engine: 2.2T
hey isn't there a bolt on top on the other side of the K frame or whatever you would call it, if its just threaded in I could weld a nut on and twist it out, and ya its broken of flush
glhsdrew is offline
Old 05-02-2005, 03:51 PM   #4
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
get a drill, and a tap... or heat it real hot and try an easyout... might try soaking it with PB blaster from on top, or drill a very small hole to put the little red straw in and soak the heck out of it for 2-3 days...
You'd be amazed at what heat can do...
Phreakish is offline
Old 05-02-2005, 06:45 PM   #5
Engine: 2.2T
ya I know how to go about get stuck bolts out, but is there a nut on the other side Im going to have to get a wrench on, or are there threads in the K frame, so that if I just twist it, it will come out get what im saying
glhsdrew is offline
Loans | Mortgages | Online Loans | Personal Loans | Mortgage Calculator
Page generated in 0.40837 seconds with 13 queries
