05-31-2005, 04:52 AM
cross drilled rotors.. pad life and other questions
Just curious if anyones runnin a pair of cross drilled rotors?
Do the pads last as long as it would on a stock setup? or less?
Also im not sure of this, but can cross driller rotors be turned or is it a one shot deal with these? Ive never done it at the shop before when I worked there because we were more of a OEM style replacment repair shop. Im debuting on the cross drilled rotors for use of a daily driver. I dont really want to go the route of dross drilled AND slotted because in the back of my mind a sharp edge would cut away at the pads and id get excessive wear with that in my mind..
Im planiing on goin to the dealership for factory pads.. cheapo replacment rotors or aftermarket cross drilled possibly..
just checkin options..
if anyone could point me in the right direction on info for this stuff, that would be great.. My key factor is relibility, longivity, stock setup or a little performance over stock..
also I was thinkin of painting the drums, calipers and the exposed sections of the rotor that dont see brake pad for sh1ts and giggles.. nothign flashy.. bronze or gunmetal im thinkin.. donno.. anythings better than rust.. Has anyone done anything creative with drum and caliper painting?
this is for a shelby charger setup basically..
thanks
Chris Pauluk
Brooklyn Park, MN
84 Rampage (SOLD)
