Old 07-29-2005, 07:58 PM   #1
Brake Caliper Piston!!
My Ride: '88 Daytona Shelby Z
How do I compress the pistons on my rear brakes? Its on an 88 Z...
DodgeGarage is offline
Old 07-29-2005, 08:02 PM   #2
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
are they on the car or off of it? if off use a C clamp to compress it, if on the car, remove the caliper , i e pry it off then compress it
xtrempickup is offline
Old 07-29-2005, 08:13 PM   #3
My Ride: 87 Z
Engine: 2.2 (+.040)
doesn't the piston look solid with recesses in the outer edge? should look like a plus sign in a way... if so they are actuated and need to be "screwed" back into the bore. For this u'll need a special tool available at the parts store. It looks like a cube with different sides for different styles of pistons. If the 88's still had the "actuated" style calipers, and u try to just force the piston back into the bore, u will destroy them. -J
87shelbyt2 is offline
Old 07-29-2005, 08:22 PM   #4
WHAT!!!!! I hope thats not my case.
Old 07-29-2005, 08:41 PM   #5
My Ride: TIII R/T
Feedback: (10)
i dunno what the heck kind of calipers you got, but any car, any yr all gens i had, and all makes have always worked the same when a c-clamp, clamping the pad to the backing and squeezing them in by turning it tight is an old way that any mechanic knows also if nothing else, undo the brake fluid fitting and the pressure will be off and the piston should release.
Old 07-29-2005, 08:55 PM   #6
The rear calipers are so small, I usually use a pair of channel-lock pliers. If your using a c-clamp and they don't move without a ton of force, go get replacements.
The rear calipers on mainly FWD GM cars thread back in with the special tool. Chrysler's rear calipers just push back in.
-Chuck James
Stevien1 is offline
Old 07-29-2005, 09:09 PM   #7
yea, they aren't budging. So I need new calipers? I need the "loaded" ones right?
This sucks. I'm running out or time. Gotta be running tomorrow afternoon and noone to take me to Autozone...
EDIT: HOLY #^%#!!! I just priced new calipers. 75 each plus a 75 core!!!!
Old 07-29-2005, 09:17 PM   #8
My Ride: 86' DAYTONA TURBO Z
Engine: 2.2L TURBO 1
A loaded caliper comes with new pads(for that side), all the hardware(brackets if any), and the caliper itself. But if it's justa seized piston I don't see the need for a loaded caliper, just get a bare caliper, it'd be way cheaper that way...
STPVIPER is offline
Old 07-29-2005, 09:22 PM   #9
My Ride: 2005 Dodge SRT-4 ACR
Engine: 2.4L DOHC Turbo
-Chuck James
the reason gm's were threaded was becuase they integrated the parking brake, chrysler's should push back in , however, if the piston has notches in it, it's threaed and has to be twisted back in - if you push you'll jump the thread and booger up the caliper bore.
rich tideswell is offline
Old 07-29-2005, 09:26 PM   #10
Rebuild them
My Ride: 05 srt4,87 omni drag
Engine: 2.4,2.2
Images: 13
I rebuilt both of my rear calipers for 10 bucks. Take an old brake pad and put it in the rear caliper. Apply shop air pressure to the caliper to blow the piston out, DONT put your hands where they can get hit. ouch!
jrbisig is offline
Old 07-29-2005, 09:35 PM   #11
no air tools. I'm doing this by hand, in the dark, in my driveway.
Old 07-29-2005, 09:36 PM   #12
My Ride: TIII R/T
Feedback: (10)
loaded calipers are the best way to go, i know they are cheaper than 75, i think mine when i was pricing them was about 45 i think with core. try advanced auto parts on the web
Old 07-29-2005, 09:57 PM   #13
advance has them, but not in stock. and they are 50 bucks + core.
Old 07-29-2005, 10:01 PM   #14
Hell, do I even need rear brakes? Can I plug the brake line and only use the fronts for a couple days?
Old 07-29-2005, 10:10 PM   #15
My Ride: TIII R/T
Feedback: (10)
i wouldnt try that, i was looking for braking about 2 yrs ago so the price might have gone up since then.
Loans | Free File Hosting | Mortgages | Mobile Phones | Daily Horoscopes
Page generated in 0.43689 seconds with 13 queries
