Old 10-18-2005, 06:48 PM   #31
My Ride: 90 Omni
Engine: 2.5 MPFI
It was bouncy with the kit's springs. There was basically no ride (think go-kart). I put up with it for about 5k mi. It made my cd deck skip like crazy too.
I believe that the dampeners used is critical though. The cheapie gabriel struts I have didn't work great with the stiff springs. I would think that a set of koni's might work much better.
V3rm3lX is offline
Old 10-18-2005, 07:05 PM   #32
My Ride: 85 shelby charger
Engine: 2.2 liter I-4
I dont mind stiff, just not bouncy. I dont want to look like a ricer with the car bouncing all over the place. Like I said I wont be driving the car except as a toy, so if it rides like a go-kart I dont mind, as long as it corners like one too. The dampening used is definitally critical to the ride, overdamped and it rides like a tank, underdamped and the car will bounch for 2 miles after going railroad tracks.
altered7151 is offline
Old 10-18-2005, 08:09 PM   #33
My Ride: 90 Omni
Engine: 2.5 MPFI
It wasn't obscenely bouncy but it was noticably uncontrolled. It would kick up and then back down pretty harshly on bumps. It would calm down after an oscillation or two. It is tolerable--especially if you have good roads in your area (Missouri has crap roads and highways). I guess is depends on how young and crazy you are.....
I plan on doing other things to get handling (boxing/sway bar/bushings) so I wanted a spring/dampener combo that still gave a somewhat decent ride. I think stock L-body springs are like 85lb/in...
V3rm3lX is offline
Old 10-18-2005, 08:28 PM   #34
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
haha, yeah, EE's are odd...
Yeah, I figured thats what it would be, hehe. But sometimes I'm surprised by something I hadn't seen before that is some kind of automotive guestimethod.
Once the rain stops (yeah, in AZ... go figure) I'll get the car in the air and measure.
Phreakish is offline
Old 01-09-2006, 08:01 PM   #35
My Ride: GLH Omni
with the 225 lbs springs i need to know the rear spring rates. are they 185lbs or higher for a generally balanced suspension. another question is will stiffer sway bars increase the handling alot with these spring rates. thank you
glhx is offline
Old 01-09-2006, 08:04 PM   #36
My Ride: GLH Omni
eibach is telling me 115lbs that sounds low for the rear sprong rate with 225 in the front
glhx is offline
Old 01-11-2006, 10:08 PM   #37
The Pope's Avatar
question, why would anyone buy a Ground control coil over kit for a Toyota for an L body when you can actually buy a Ground Control coil over kit for an L body for an L body? I am lost. And if you buy the L body kit buy 7" front springs and bolt on G body struts, they are cheaper. Otherwise you need 9" springs as the 7"s are too short. I have this kit on my L body with GLHS rear Konis and G body front Konis and 4 wheel bolt on 11" disk brakes. 7" rear Eibach 250 lb springs lower the car 2" at the top of the adjuster. I didn't want my car "slammed".
Rob
The Pope is offline
Old 01-11-2006, 10:34 PM   #38
Do they still make a kit for l-bodys?
Travis_k is offline
Old 01-11-2006, 11:01 PM   #39
The Pope's Avatar
yes, but they don't list it. You need to call for a part #. I can look on my box too lol.
Rob
The Pope is offline
Old 01-12-2006, 12:28 AM   #40
Is it a set of 4? Or just 2 for the front.
Travis_k is offline
Old 01-12-2006, 01:32 AM   #41
The Pope's Avatar
set of 4, whole car. 325 lb fronts and 250 lb rears. Kit comes with 7" springs and should be 9"
The Pope is offline
Old 01-12-2006, 02:18 AM   #42
What did you have to change to put g-body struts on your car?
Travis_k is offline
Old 01-12-2006, 10:41 AM   #43
The Pope's Avatar
So I could bolt on without grinding or slotting 89 Shelby Daytona knuckles and 11" disk brakes. They are also over $100 cheaper than L body struts for Konis.
The Pope is offline
Old 01-12-2006, 11:42 AM   #44
I mean what exactly is different? So you just took a set of daytona front spindles and hubs and put then on and thats all thats different?
Travis_k is offline
Old 01-12-2006, 12:55 PM   #45
here is my old L body with $10 coil over kit on stock monroe struts (I cut off the spring perch on my cnc lathe). the blue part is the threaded collar and it sits on the knuckle mount. I used 350# 12" x 2½" stock car springs.... parts were $5 each from a local race car parts store that also carries used and consignment equipement.
allmotor is offline
Ringtones | MPAA | Gas Suppliers | Loans | Homeowner Loans
Page generated in 0.48204 seconds with 13 queries
