I'm Nick and drive a 1988 Daytona Shelby. Thought I would make my way over here and let you all see my baby. The car was built by the LittleShop I think you all might know him here as Rob or Shadow.
Well on to the pictures!! and mod list...mod list might be missing a few things. sorry for the size of the pictures!!!
The car is running 20 psi and made a G-tech run with 110 MPH give or take a MPH in 27 + degrees Celsius with no weight reductions.
The specs.Engine
-2.5L
-fully ported G-head with all the goodies(1mm over sized valve's, ported ect.)
-forged pistons
-removed balance shafts
-new rod bearings
-Head cooling mod to above the #4 cylinder
-solid front mount
-solid bobble strut CUSTOM
-twin front mount intercoolers
-3 inch custom swing valve
-3 inch custom exhaust dumps before the middle of the car
-aluminum rad
-new trans was built using a a523 casing and a 1989 a555 guts to make me a
custom a568 shimmed diff
-40 trim turbo .63 exhaust housing 48.wheel
compressor housing cut and re-welded for factory fit!
-modified talon 1g BOV
-3 inch cold air intake
-mopar performance head gasket copper coated
-high flow oil pump
-windage tray in the oil pan
-head studs
-two piece intake Ported
Electronics
-stage 5 computer
-mangnicore sparkplug wires
-rny9 champion spark plugs
-3 bar map sensor
-gauges A/F and BOOST pillar pod
Fuel
-40+ injectors
-super 60 fuel pump
-adjustable pressure regulator "motion performance"
suspension
-mopar struts - stock Shelby springs
-monro sensitrac - stock Shelby springs
-poly urethane bushings all around
-stock braking system
The specs.Engine
-2.5L
-forged pistons
-new rod bearings
-solid front mount
-aluminum rad
-high flow oil pump
-head studs
Electronics
-stage 5 computer
-3 bar map sensor
Fuel
-40+ injectors
-super 60 fuel pump
suspension
