84 rebuild - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Electrical Help and Discussion area for any Electrical issues/diagrams.
post #1 of 4 Old 02-17-2017, 11:35 AM Thread Starter
My Ride: 84 and 2 89 Daytonas
84 rebuild
Im going to update my 84 Daytona to a 88 Daytona Shelby was wondering if anyone at links to any info on doing a update so i can read up on it before i start the project
vince8489 is offline
post #2 of 4 Old 02-18-2017, 01:28 AM
Hybrid Booster
Re: 84 rebuild
Johnny Dodge posted on this a while back if I remember correctly.
Hopefully he will see your post and chime in.
What all are you changing, electrical system??
Engine and trans.??
Body parts??
Engine and trans are straight forward using the 1988 axles, shifter and cables.
Thanks
Randy
Glhs60 is offline
post #3 of 4 Old 02-18-2017, 11:45 AM Thread Starter
Ya I'm doing motor and trans, and was told everything needs to be changed, so I'll probably do some of the interior as well but would like to know what exactly needs to be done and how everyone that has done this made it possible
post #4 of 4 Old 02-18-2017, 06:37 PM
Hybrid Booster
Re: 84 rebuild
Very few have done much with the 1984's as they were a single year electrically and electronically.
From memory John Dodge posted a while back about the wiring swap.
As you probably know the 1984 has the Logic Module in the passengers side kick panel and a Power Module beside the battery, as were all 1984-1987.
1988 went to a SMEC style electronics with a single module beside the battery.
Assuming you remove the 1984 under hood wiring and LM that leaves you with installing the 1988 engine harness.
The actual Engine part is no issue as its the matching Engine but the headlights are the main underhood difference.
The next issue is the bulkhead connector, I know the 1988 goes through a grommet in the firewall and connects with the fuse box.
I'm not sure but I believe the 1984 bulkhead connector is right at the firewall and there is your issue.
I've only done L bodys with a bulkhead connector so when joining it to the SMEC harness I chopped off the Engine side wiring coming out of the bulkhead about 1 ft.
I also chopped off the SMEC harness where it goes through the firewall and spliced them together.
It's not that complicated as most of the wires are for lights, gauges etc.
Alternatively, you could strip the entire harness from the 1984 and replace the Engine, dash and rear body harness with the 1988.
The 1984 and 1988 don't connect at the firewall/bulkhead/fuse box/dash harness is the main issue to consider.
Thanks
Randy
86 GLH S60
86 GLHS 373
89 Turbo Minivan
83 Rampage Turbo
Glhs60 is offline
Human Verification
