09-27-2005, 12:11 AM
Your power loss lamp will emit a series of flashes to reveal a code. Example: Flash*short pause*Flash*Flash*Flash*long pause would read as code 13, which I'm willing to bet will be one of your codes. www.minimopar.net for more in depth info. I believe there are 5 trouble codes that will cause the lamp to stay on while driving, each of which will put the logic module into 'Limp Mode', meaning one or more sensors is far enough out of range to force the computer to disregard info from that sensor and basically fill in the blanks based on info from other sensors. A vacuum leak would cause an irregular signal from the MAP Sensor, setting code 13.
Now the question I must ask: WHAT was shorted out to cause EVERY fuse to blow?
