09-27-2005, 12:23 AM
So either way, your car is not charging? First off, put everything back to stock. Take the alternator into the parts store and have it tested. It's not unheard of for rebuilt alternators to be bad right out of the box. Might as well do the battery as well while you're at it. If/when they test good, physically inspect the wiring from the alternator harness all the way to the cluster of wiring under the battery tray. Look for any corrosion, frayed wires, or broken connections. Key points will be the ground attachement on the alternator itself, the ground cable usually bolted to the cylinder head, the white bullet connector off of the negative battery cable, and I believe two or three black wires bolted directly to the frame rail under the battery tray. Also check all fusible links and make sure your battery connections are good. IF all else fails, I have a known good PM we could make a deal for. If you have any questions, let me know, I've had this problem a few times.
