Old 10-14-2005, 09:11 PM   #1
How-to: Radio turnoff delay circuit
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Ok. First I'll start with the reason you might want this circuit. Most modern American cars have a radio delayed turnoff feature. What it does is it keeps the radio on after you turn the car off. The radio stays on until the driver's door is opened. It's amazing how quickly you can come to expect this feature to be in all cars. It's also remarkably easy to add to any car, I have added it to at least 6 or 7 of my cars and past cars. The only cars I could see having a problem with this circuit would be positive door triggered cars, such as Ford's. But it's a small revision to get it to work with even them.
Anyways, let's go into an explanation of how this circuit works. Using two standard readily available Bosch style relays, once the ignition is turned on, one relay is put into a self-sustaining power loop, the other relay is just there to break the loop. A diode on the incoming accessory wire from the car keeps the power from backfeeding into the rest of the car (this would blow the accessory fuse, don't get any ideas). The accessory circuit also feeds the radio, so that opening the door with the car running does not kill the radio.
I appologize for the crudeness of my schematic, I'm far from being an artist. The funny looking loop of wire near the incoming constant 12v source wire is to let you know that those two wires are not connected. If you look at the bottom of a Bosch relay, the terminals should look the same and have the same numbering. You have to use SPDT relays, SPST relays commonly used for foglights will not work.
This circuit will work with the stock radio, I have it setup that way in my turbo Horizon. But I recommend doing it with an aftermarket deck and harness adapter, it's easier if your not chopping into the factory wires and trying to figure out which is constant and which is switched.
As for getting ONLY the drivers door, not the passenger door(s), you'll need to pull the kickpanel on the driver's side, pull the door pin, and find the wire coming off of it going to the dome light. (It's yellow on our TD's) Find the wire in an easily accessible place, and cut it. This will kill your dome light. Worry not. You need a 3amp or larger diode, Radio Shack or some other electronics store will have them. You want to put the diode in that wire where you just cut it, the diode will have a white stripe on one end, you want that stripe on the doorpin side of that wire. You also want the wire going to your radio circuit on that side of the diode. Hook the other side of the diode to the dome light side of the yellow wire you cut originally. This will keep your dome light working, and keep your passenger getting out from killing your radio.
I assume there will be many questions, feel free to PM me. Please leave me some positive feedback if you find this helpful.
<---------Feedback button.
Una is offline
Old 10-15-2005, 07:21 PM   #2
Una
Engine: 2.5L Turbo
Only 5 views.. Hmm.. Look at me, look at me.. heh
Una is offline
Old 10-23-2005, 07:27 PM   #3
My Ride: 92 Iroc R/T Red
Engine: TIII
don't worry dude I was one of the first views and copied it. I have plans for it. It may come in handy with my home made shut down systems on some diesels at work. I also may use it when I hard wire my xm to shut off when I get out of my van. Thanks
Tim
charger R/T is offline
Old 10-23-2005, 08:32 PM   #4
Una
Engine: 2.5L Turbo
Cool. I may hang another relay off this circuit in my Daytona so I can keep the power windows goin till I get out as well. Real annoying not being able to roll the windows up after I shut the car down.
Una is offline
Old 10-27-2005, 10:47 AM   #5
My Ride: 1990 Spirit
Engine: 2.5 T1
I like this info alot.... probably do this in my show-car (85 Monte Carlo)
90Acclaim is offline
Old 11-04-2005, 05:20 PM   #6
Una
Engine: 2.5L Turbo
It's really handy in a daily driver, nice being able to shut the car off when I get home and continue to listen to the music or whatever they're talking about.. But it does have a neat factor that'd be cool in a show car.
Una is offline
Old 11-04-2005, 07:14 PM   #7
My Ride: 87 Shelby Z
Planning on a similar circuit for my 88 Shelby Z TI When I swap in a 91 413 with lockup. I'm just planning on using the brake circuit to disengage the relay for the lockup. That way you can get going down the road and hit a button to engage the lockup. Once you hit the brake it interupts the circuit and unlock the TC. Should be simple enough although by thretening to change the trans in the 88 it started shifting perfectly. I swear TD's have ears!
Benji Farr
Green Bay WI
87 Shelby Z TII 15.2 @ 90.7
88 Shelby Z TI 2.2 auto
91 Shelby TI 2.5 5spd
http://bfarroo.tripod.com
http://www.extremepsi.org
bfarroo is offline
Old 11-04-2005, 07:19 PM   #8
Una
Engine: 2.5L Turbo
Ahh, I should try that.. Threaten the tranny in my '88 Horizon.. haha, actually, I think it already feels threatened since I have a spare TBI tranny ready to go at a moments notice, so I can continue to drive the car while I rebuild the bad tranny.. hehe..
I still have dreams of someday talking someone in the D-Cal list into putting the lockup torque converter routines from a TBI cal into the turbo cal.. I even have the image off an '89 automatic TBI computer.. Just gotta get a wizard to do it..
Una is offline
Old 12-17-2005, 06:45 AM   #9
redraw
My Ride: 1988 Grand Caravan
Engine: V6 3.0L
i took it on myself to redraw the scematics you drew by hand... sorry if it offends you, i installed the mod on my 88 grand caravan with a Pioneer Sterio and it works great...
EagleGcIL is offline
Old 12-17-2005, 08:31 AM   #10
Una
Engine: 2.5L Turbo
Cool, that works. Thanks.
Una is offline
Old 12-17-2005, 12:00 PM   #11
Engine: V6 3.0L
If you want a copy of the schematics i drew up, let me know, i'll email you them.
Old 03-16-2006, 01:26 PM   #12
Mo' valves, mo' boost
jonnymopar's Avatar
My Ride: Daytona
Engine: 2.4L DOHC
HA! Not when you have a NEON!!
Thanks for this info. I'll have to try this. I'm with whoever said the thing about the power windows too!
Jon J.
1989 Daytona 2.4L - MPH
2003 Neon SXT - MPG
jonnymopar is offline
Old 08-19-2006, 07:31 PM   #13
My Ride: 1987 shelby charger
Engine: 2.2 t1/t2 conversion
what a great idea........as soon as i get my tail lights working i will try this
dan
eef mcglikn is offline
Old 08-19-2006, 07:54 PM   #14
Una
Engine: 2.5L Turbo
Gotta wire up this circuit in my Kia.. Just gotta track down a couple diodes..
Una is offline
Old 10-17-2007, 05:37 PM   #15
Re: How-to: Radio turnoff delay circuit
My Ride: '01 Nissan Sentra XE
The redraw helps a lot... this is pretty smart stuff...
dodgeballer is offline
Debt Consolidation | Loans | Bad Credit Mortgages | Web Advertising | Credit Card
Affiliates: GTcars.ca - DodgeIntrepid.net -
