Old 10-28-2005, 01:50 PM   #1
Question Dash wiring pinout?
My Ride: 82 Dodge Rampage
Engine: Turbo I 2.2L
Hey, does anyone have the dash cluster wiring pinout for an 86 Shelby Charger? I just bought an Omni/Charger Haynes service manual thinking it would have the whole wiring diagram for the dash harness, and it didnt, . I am putting in a custom gauge cluster in my Rampage using Autometer Sport-comp series speedo, oil press, water temp, volts and fuel level gauges, and i need to know most of the original wiring so i can splice into it.
Thanks in advance
Turbo_Rampage is offline
Old 10-28-2005, 02:19 PM   #2
Old School Hot Rodder
85lebaront2's Avatar
My Ride: 1985 LeBaron Vert
Engine: MOPAR 2.2L
I have it at home, I will scan and send when I get home later.
Bill Vose
1986 Turismo 2.2 (race car)
1986 LeBaron convertible 2.2L TBI (dead)
1986 F350 Crew Cab DRW
1993 Grand Caravan 3.3L
85lebaront2 is offline
Old 10-28-2005, 03:28 PM   #3
Thanks alot!!!
Old 10-28-2005, 09:46 PM   #4
Engine: MOPAR 2.2L
Need your email in order to send it.
Bill Vose
Old 10-28-2005, 10:07 PM   #5
turborampage@hotmail.com
Thanks again!
Old 10-29-2005, 03:45 PM   #6
Engine: MOPAR 2.2L
Scanner power supply burned out, I have one ordered, but in the mean time I will give it to you by description. There are two plugs, a round 11 pin that has it's terminals labeled A - L and a straight 10 pin numbered 1 - 10. Round first, starting at the key:
A. no connection
B. 20ga. Black, brake warning light
C. 20ga. Gray/Light Blue, tachometer (Rally Cluster Only)
D. 20ga. Dark Blue, fuel gauge
E. no connection
F. no connection
G. 20ga. Orange/Light Green, fuel pacer lamp
H. no connection
J. no connection
K. 20ga. Light Green, left turn signal indicator
L. 20ga. Dark Blue/Red, seat belt warning
Straight connector 3 pins, key, 7 pins. 1 - 3 above key, 4 - 10 below.
1. 16ga. Red, high beam indicator
2. 20ga. Tan, right turn signal indicator
3. 20ga. Dark Blue, ignition feed
Key
4. no connection
5. 20ga. Grey, low oil pressure light
6. 20ga. Black/Orange, power loss light (Turbo Only)
7. 20ga. Grey/Yellow, oil pressure gauge (Rally Cluster Only)
8. 20ga. Violet, Temperature lamp or gauge (Standard or Rally Cluster)
9. 20ga. Black, ground
10. 20ga. Orange, illumination lamps
Hope this will help you, I will scan it for you when the replacement power supply arrives.
Bill Vose
Old 10-30-2005, 01:28 AM   #7
Awesome thats just what i needed! I will post up some pics when i get this custom gauge cluster in my Rampage..
Thanks again!
Old 10-30-2005, 09:06 AM   #8
Talking
Thanks again!
Me too--Muhco thanks for this info--Makes life easy when converting carb to SMEC when all you have is SMEC prints---bobr19
bobr19 is offline
Old 11-28-2005, 07:04 AM   #9
bump
bobr19 is offline
Old 12-05-2005, 10:50 AM   #10
Engine: MOPAR 2.2L
Finally got the scanner back up and emailed the scans to turborampage@hotmail.com hopefully it wasn't stripped of the attachment.
Bill Vose
Modded Xbox | Free Advertising | Remortgages | Mobile Phone | Car Loan
Page generated in 0.36318 seconds with 13 queries
