Old 11-22-2005, 04:50 PM   #1
charge air drilling
I need to install a charge air sensor on a 1-piece intake. Since I don't have the sensor yet, what size threads are they?
anonymous_user is offline
Old 11-22-2005, 08:01 PM   #2
My Ride: 85 GLHT, 87 ShelbyZ
3/8ths pipe tap and a 37/64ths drill.
GLHNSLHT2 is offline
Old 11-23-2005, 04:05 AM   #3
Thanks
Hmm...
My sources tell me that 3/8-18 NPT takes a 9/16 drill bit. 37/64 is only a weee bit bigger. Shouldn't make a difference, should it? (I don't have a 37/64 bit)
Old 11-23-2005, 06:16 AM   #4
Originally Posted by anonymous_user
Thanks
Hmm...
Should work fine--bobr19
bobr19 is offline
Old 11-23-2005, 09:46 PM   #5
McMaster carr has a one for not too much $$$. Just get it with a reduced 3/8ths shank. With how thing the metal is and getting that pipe tap started I'd rather have the extra .013 thou.
Old 11-29-2005, 10:04 AM   #6
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
Go with the smaller bit, especially if you are hand-drilling. The casting is aluminum and the tap is tapered, so it will have no problems taking out the extra material. When hand-drilling a hole to be tapped, I always take 1/64th off the recommended size, since the drill will tend to hog-out about that much even with the steadiest of hands.
minimopar is offline
Old 12-05-2005, 02:41 PM   #7
FWIW, I have done a dozen or so with a 9/16" bit and a hand drill and they all worked fine. I have found that I get best results by only running the tap about 1/2 to 3/4 of the way in, or the sensor comes close to the end of its threads. I wouldn't want to use a bit any larger or the sensor would be too loose. Like GLHNSLHT2 mentioned be mindful of chuck size as well, most standard bits that size won't fit in a 3/8" chuck hand drill.
william is offline
Old 12-07-2005, 05:53 PM   #8
Engine: 1987 2.2L
You can also get larger adapter chucks at the hardware store that will thread on the smaller drill shafts. Good for making a cheapo drill more useful or handling large bits in a cordless.
Pacotes Reveillon Salvador | Pay Day Loans | File Sharing & Mirroring | Read Boing Boing News | Finance
Page generated in 0.42824 seconds with 13 queries
