11-30-2005, 05:37 PM
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
Agreed. Pulling the sensor wire makes it go into limp-in. Sounds like the sensor is not out of spec enough to trip the limp-in mode and turn on the fan, but it is giving false readings. It may be hurting your fuel mileage too.
I had this happen to me once. Both the coolant and charge temp sensors were out of whack in a similar way and the car would flood at startup in certain temperature ranges and had bad mileage. After changing both sensors, everything was fine.
