Old 12-20-2005, 01:29 PM   #1
90 daytona alarm
I have had my car with no alarm button for almost a year. Today I go out and open the drivers door and the alarm goes off and won't let me start the car. I cant figure out what to do to disable it, I cant even more the car to change the oil which is all I wanted to do. Please help me someone
qzone83 is offline
Old 12-20-2005, 04:28 PM   #2
My Ride: 87 Shelby Charger
Feedback: (6)
LOL alls I can suggest is to find the actual alarm module, and unplug the harness.....
my guess it would be located somewhere underneath the dash???
maybe someone who actually has a factory alarm can let ya know.
Juggy is offline
Old 12-20-2005, 06:58 PM   #3
Have you tried unlocking the car with the door key lock cylinder? They have the disarm switch connected to the back of the lock cylinder. If the driver's side lock does not disarm it, try the passenger door lock cylinder. If that does not work; remove one of the door trim panels and locate the disarm switch connector(rear part of the door) and "jumper the two wire terminals on the connector and the alarm should turn off.
Phil
shelbyrampage is offline
Old 12-20-2005, 07:03 PM   #4
thanks, unlocked the passenger side and it shut off, anyone know where i may be able to find a controler for the factory alarm, I didnt even know that it had one
qzone83 is offline
Old 12-20-2005, 07:07 PM   #5
It would probably be a good idea to buy a remote transmitter for the alarm. It does not sound like it is bad, just activated by accident.
Phil
Old 12-20-2005, 07:39 PM   #6
Blue Iroc R/T's Avatar
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
First, try the security alarm self diagnostics. Get in the car, close all doors. Turn the key from OFF to ACC Three times (same as checking engine codes, except turn to ACC instead of ON). Follow these instructions to check out the alarm system. http://www.pbase.com/rmscott/factory_security
Disregard "Fig. #3" on page 4, it's for a AC & AY body car.
DO NOT, DO NOT, DO NOT try to remove the control module unless the car is running.
Also read these two threads, (they had a similar problem):
factory alarm
Factory alarm
Good Luck & Merry Christmas.
Ralph
Blue Iroc R/T is offline
Old 12-21-2005, 01:16 AM   #7
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
So, what happens if you do? I don't want to be the first to try. I hear it could be bad things.
phantomrt is offline
Old 12-21-2005, 04:35 PM   #8
cky
My Ride: 90 daytona shelby
Engine: 2.5 intercooled
your engine won't run until its reinstalled.
cky is offline
Old 12-21-2005, 05:13 PM   #9
anyone know where I may get a remote for the alarm?
qzone83 is offline
Old 12-21-2005, 08:02 PM   #10
Engine: 2.2l TIII
They don't make a remote for our alarms. I have often wondered if the "Remoter Keylesss Entry Module" for the AC & AY Body shown in figure #3 could be adapted to work on our system. http://www.pbase.com/rmscott/image/29092784
It might even be a plug &play. The lamp outage module and Theft Alarm Module look to be the same.
Sorry for not explanining the DO Not remove the alarm module. If removed without the car running, the car will not start, without re-installing the module. If you remove it with the car running, it de-activates the whole alarm system and everything works as though the car never had a alarm system.
I doubt that the alarm module is bad on your car. It is probably one of the switches that is bad. Running the self diagnostics and opening/closing the doors & Hood will tell you which one or ones are bad.
Ralph
Old 12-23-2005, 12:54 AM   #11
Its funny how the one day the alarms in these cars cause a problem then suddenly they want it to be completely removed. They decide this AFTER they figure out how to use it and disable it, etc.
Homes for Sale | Synchronization fast and easy | Personal Loans | How to Camp Out | Problem Mortgage
Page generated in 0.37473 seconds with 13 queries
