01-26-2006, 02:03 AM
dash harness?????
My Ride: 88 t-top Shelby-Z
Engine: 2.2 turboII
Well that is something you will have to look at. Check the pins in the connectors. Ma Mopar has done wierder things in the past with using antthing on the shelf to get the cars out. I know for sure that carbuated to tbi yes, the harness has to be changed, but they might be the same between tbi and turbo.......oh hey don't forget that theres that computer in the passenger kick panel as well, so chances are more likely yes.
Reason: missed word
01-28-2006, 11:46 AM
My Ride: 89' Dodge Daytona ES
Engine: 2.5 l4
88 is the first year of the smec, the reason you need a turbo harness is because tbi harness isnt prepared to fire the injectors and acept charge air sensor, wastgate solenoid, hall efect pickup has another plug and other things, you should look for the whole thing, you need the injector wiring harness, alternator sub harness if it dosnt come conected already to your turbo harness, it conects under dash..to the rest of the engine (watch the route of your current harness because you route it the same way, i used my tbi starter sub harness for my proyect)
01-28-2006, 11:55 PM
My Ride: 84 Chrysler Laser XE
Engine: 2.2 Turbo II
Its alot easier to get an 88 E class turbo harness, then add the air charge temp sensor.
01-29-2006, 11:52 AM
Dodge 600, Chrysler New Yorker, Lebaron Sedan, and Plymouth Caravelle.
