Old 02-12-2006, 11:06 PM   #1
No back up lights! 88 daytona
I've tried fuses, bulbs and looking at obvious connectors etc. I have no reverse lights so i was wondering what else could c ause this problem? i heard something about a control module under the pass side kick pannel however didnt see much when looking. the car is an 88 daytona 2.5Tbi auto. Please help!
thanks!@
brandon
spoolerr is offline
Old 02-13-2006, 08:41 PM   #2
My Ride: 92 Iroc R/T Red
Engine: TIII
The reverse light switch is combined with the nuetral safety switch. Its a 3 wire connector on the front of the trans. Probibly closer to the drivers side of center on the front of the trans. The center wire is the neutral safety wire. That wire gets grounded to the trans in park and nuetral to crank the engine. The other 2 wires are the reverse light wires. Try jumping them together and see if the lights come on. If they don't come on get a test light and check the wires for power. 1 of them should have power on it with the key on.
Tim
charger R/T is offline
Old 02-13-2006, 09:15 PM   #3
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
I had a similar problem with my 93 Baron. I had volts to the bulbs, so I wasn't sure what was going on. But the fix was rather simple. I just added two ground wires to the sockets. Everything works great now.
I've found that the liscense plate and both reverse lights share the same ground. And mine was bad at the point of the factory splice.
Wink
mwinkle353 is offline
Old 02-14-2006, 03:29 PM   #4
thanks guys, i will try those suggestions!
brandon
spoolerr is offline
Old 02-14-2006, 10:04 PM   #5
thanks guys, awsome advice. i grounded the two outer wires and the lights came on : )
so i grabbed aswitch from a car at the wreckers and everything works awsome aside from a blown passenger bulb, but i do have 12V and a ground when in reverse so i'll pick up a bulb tomorrow
thanks for the sound advice
brandon
spoolerr is offline
Credit Cards | Shares | Loans | Secured Loans | Per Insurance
Page generated in 0.31939 seconds with 13 queries
