Old 02-14-2006, 08:03 PM   #1
87 LeBaron analog to digital instrument conversion
My Ride: 1987 LeBaron J-body
Does anyone know how to do the swap from analog gauges to digital ones on an 87 LeBaron (J-body)? I have a digital cluster out of an 87 LeBaron that is identical to my car, but the plugs on the digital cluster are round..digital ones are square..
The digital cluster physically fits in my dashboard.
Any help would be appreciated.
pinball9818 is offline
Old 02-14-2006, 08:44 PM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
You need the '87 electrical factory service manual. Then the correct connectors with a couple inches of wire.. Splice splice splice..
Una is offline
Old 02-14-2006, 09:26 PM   #3
Cool thanks! Could I assume that I should just splice wires of the same color? Or is that a bad idea?
Old 02-15-2006, 01:12 AM   #4
I have the connectors if you need some. PM me if you want 'em.
TurboBaron is offline
Old 02-15-2006, 04:57 AM   #5
Go over to the daytona forums at allpar.com and use the search button. This topic's been covered at least a dozen times there.
DaytonaTurbo87 is offline
Old 02-15-2006, 07:00 PM   #6
Una
Engine: 2.5L Turbo
For the most part, yes, colors are the same. But the digital cluster got several inputs the analog didn't. You'll need to track those inputs down. A wiring schematic is handy for that sort of thing.
Una is offline
Old 02-17-2006, 11:14 AM   #7
Thanks for all the help!
Old 02-17-2006, 12:45 PM   #8
Feedback: (32)
http://www.hardcars.com/headerman/dodge/digidash/
tryingbe is offline
Old 02-17-2006, 01:59 PM   #9
Ive been searching for a while on a simular question, and havent found anything.
My '86 Daytona has a cable speedo, do I need to do anything for the '86 digital speedo to work? or do I just not hook up the cable?
WildkatCT is offline
Old 02-17-2006, 08:54 PM   #10
Una
Engine: 2.5L Turbo
Just make sure the VSS (vehicle speed sensor) on the transmission is still good. If you get an error code for it when you check codes, it's not. I think most of the cars still had the big unreliable one in '86.. They got more reliable over the years.
Una is offline
Loans | Mortgage | Cheap Loan | Best Credit Cards | Loans
Page generated in 0.35384 seconds with 13 queries
