Old 02-25-2006, 02:13 AM   #1
one more stereo question
My Ride: 1993 duster
Engine: 3.0 v6
i put a system in my 93 duster a few months ago. (300watt amp, 12" sub, old pioneer head unit, new door speakers)...
rigth now i only have the sub wired into the amp. if i put the speaker wires into it, would it improve sound quality over the speakers being plugged into the head unit? right now it sounds decent, but its not where i'd like it to be.
thanks,
'Jim
imfamousjim is offline
Old 02-25-2006, 02:18 AM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Do you have unused channels on that amp? If you hook your door speakers into the sub amp, you'll either have no treble, or have tons of treble coming out your sub. Unless it's like a 4 channel amp or better, then you can do half and half on one amp.. And generally, you only get a modest audio quality improvement moving to an external amp. It does increase volume level before distortion tho. What really improves audio quality are the more expensive decks. If you can't afford one, buy a used older model on Ebay.. Like 3 or 4 years back, try to buy that year's "best" model. The audio quality on the top model (often called the 9 series) is far above the base couple of models. They also tend to have more features.
Una is offline
Old 02-25-2006, 02:23 AM   #3
thanks,
'Jim
I'd say no way. Especially without knowing anything about the amp or how it's hooked up.
dwh4784 is offline
Old 02-25-2006, 02:24 AM   #4
Engine: 3.0 v6
yeah my head unit is real bad... but atleast it plays cd's (most of the time)... im almost positive my amp isnt a 4channel so there goes that idea.
ill prolly go looking for a newer head unit...
thanks
'Jim
Old 02-25-2006, 02:10 PM   #5
BFnGA's Avatar
You can run a sub on a 2 channel setup . It's not the greatest , but will sound better than just amping the sub . Hook up left & right as normal , and then hook the sub up to (L+) & (R-) , or vice versa , if your amp is labeled to bridge the other way . It's sort of a quasi-three channel . Sorta ghetto , but will sound better than the way it is now .
BFnGA is offline
Old 02-25-2006, 02:17 PM   #6
Una
Engine: 2.5L Turbo
Like I said.. Without a passive crossover, he'll get tons of treble out the sub that way.. And usually not much bass without seriously cranking the rest of the system.. It's a really poor option.
Una is offline
Old 02-25-2006, 03:21 PM   #7
BFnGA's Avatar
Like I said "sorta ghetto" , but it WILL sound better than just amping the sub , up to the point the amp distorts . You can't crank it , but it will sound much better , and fuller "moderately" loud . Moderately being relative to the quality of the amp .
BFnGA is offline
Old 02-25-2006, 03:39 PM   #8
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
i have a 2 channel amp thats bridged powering a 8in sub station and i get decent bass out of it, not a lot of treble. surprising in the daytona it sounds fine
xtrempickup is offline
Old 02-25-2006, 03:50 PM   #9
Engine: 3.0 v6
i obviously dont know much about systems... but i think mine is bridged that way... i believe its the negative right to positive left.
im thinking its just having a bad head unit. base and treble from the sub are fine, but overall sound quality of the whole system is just lacking something.
Old 02-25-2006, 06:06 PM   #10
I'd still like to know what kind of amp you have..."300 watt" really means nothing as that's probably a "max" rating and the actual output is around half of that. Same goes for the sub, what are the brand/specs on it? If you want to keep what you have now and still improve on it, I would buy a mono sub amp for the sub and use the 2 channel you have now on the new front speakers. Let the head unit power the stock rears. I've ran multiple amps before and it's not a big deal.
dwh4784 is offline
Old 02-25-2006, 06:13 PM   #11
You say bass and treble from the sub are fine...there's a problem with that. Subs should only play low frequencies, if your amp has a low pass filter turn it on...if it doesn't then you should really get another amp. That's killing your sound quality right there.
dwh4784 is offline
Old 02-28-2006, 11:53 AM   #12
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
^^^ +1
daytonajesse is offline
Credit Cards | Mobile Phones | Remortgages | Equity Release | Mortgages
Page generated in 0.42624 seconds with 13 queries
