03-03-2006, 11:27 PM
Sweeping needle on volt meter? Help....
I searched around for a while, but I couldn't locate anyone with my exact problem.
Yesterday I was driving my '89 Caravan when suddenly the needle on the volt meter started to sweep wildly back and forth. I was pulling into a parking lot anyway, so I stopped, waited a minute, and it returned to normal. Then, on my way home the voltage dropped to about 1/3 from the left (a bit above the "red" zone) and my check gages light came on. It would fluctuate a little bit as I drove. I started it up after work and the voltage was right back in it's normal spot (I'm guessing that's 14v--norm, rght?). I took it to Sears on my way home from work to have an alt. test done because the voltage dropped as I drove it. First, they said I needed a new battery (doesn't suprise me), then they did the test and the alt. started at 14v and then dropped to 12v. They suggested replacement. I was going to take the alt. off my other van tomorrow, but today, the gauge was fine all day!
I read quite a few posts on kaput voltage regulators. Could this be my problem? Maybe a shorted line? Or do I just need a new alt.? I'm new in the electronics dept.
I guess I could just change the alt. tomorrow and see, but it's only 31 degrees tomorrow, and I figured I'd ask for a few suggestion before I freeze myself.
Oh, it was also snowing quite a bit yesterday. Could water have affected the system somehow?
Thanks,
Ian
