03-30-2006, 04:55 PM
Originally Posted by blacklab78
I already had the crank sensor fix. when the crank sensor went the mechanic fix the crank sensor then when I drove it home. got it home then it started sputtering and trying to stall even stalling a few times we would unhook the battery for a few minutes then it would drive for a little awhile, brought it back to the mechanic and he said he don’t know but he change the coil, we drove it home again, it was starting only in the after noon run good for a little while, then in morning same problem all over again. It did that for a few days but now it won’t even start most of the time and if you do get it to start it stalls right away. My question is that sound like any particular that was starting to go? Or do you think the mechanic installed the crank sensor wrong?
I think you should keep taking it back until it either blows up or it gets fixed. have the "mechanic" replace the crank sensor again, cam sensor, coil again, fuel pump, fuel pressure regulator, all the injectors, the computer and what ever else he can. eventually something needs to fix your problem.. or better yet, sell it on ebay as is then get another vehicle.
