04-02-2006, 09:56 PM
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
the brake light striker on the brake pedal needs to either be swapped out or custom made.
happened to me when i did my conversion. melted the rear third brakee light box with the lights staying on.
for my conversion i had to custom make my striker. the brake light switch is bolted to the pedal assembly bracket that goes around the steering column at the firewall, behind the brake pedal.
i couldn't swap the striker from the original pedal cuz the striker was WELDED to the pedal (so i couldn't remove it) plus the striker was positioned differantly. luckly the donor pedal had it's striker bolted on so i just grabbed some spare iron, copied the original welded striker, ground it and bent it to shape and bolted it on. works like a charm.
