Old 06-26-2006, 12:45 PM   #1
88 T1 into an 86 Dodge 600
Hey everyone, I originally posted this on the Engine management section, but was refered to this section, so here is my question,
I wanna put an 1988 T1 engine from a LeBaron into our 1986 Dodge 600 (Orig 600 engine has a bad turbo and is worn out)
What is the easiest way to do this?
I have the SMEC and the wiring harness from the LeBaron.
Any help and advice much appreciated !!
kingsturbo is offline
Old 06-27-2006, 01:54 PM   #2
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
Well, you have a few choices. The 1988 T1 is a 2.2L, so you can add the two extra wires for the 88 AIS motor and find yourself a 1986 T2 LM (GLHS only). You could make a few more wiring mods (MAP sensor relocation and swapping some pins on the LM connectors) to move up to 1987 specs. 1987 T2 LMs are easier to find. If you do either of these, you'll just have to do some splicing at the throttle body harness and you'll have to find a place to put the air charge temp sensor (88 T1 doesn't have one). The rest of the original engine harnesses should work fine on the 1988 motor.
You could go all the way and do a complete SMEC conversion. This requires a great deal of splicing and harness work, since you will either have to splice the SMEC engine-related wiring into the 86 harnesses or you will have to remove the 86 harnesses and splice the SMEC body-related wiring into the 86 harness (mainly at the bulkhead connector).
minimopar is offline
Buy Anything On eBay | Personal Finance | Mortgages | Loans | Online Loans
Page generated in 0.28293 seconds with 13 queries
