Old 06-29-2006, 07:18 PM   #1
Omni Glh Fan Relay?
My Ride: GLH-T
Wheres the fan relay on a 85 glh? and what wires are which going to it? Thanks...
87DANCEonYOU is offline
Old 07-03-2006, 12:18 AM   #2
Its on the driver side strut tower to the right of the starter relay. Its the closest "little box to the fender"
Light green is going to your fan motor "I figure this is the one you want"
gray to the charging system
black with white tracer to starting system
pink to logic module
and I would imagine black is to ground
This is all depending on that your car is turbo if not there is no pink wire, it is instead a black wire that runs to your spark advance.
Eastburn_420 is offline
Old 07-03-2006, 11:58 AM   #3
My Ride: 85 GLHT
A little info and some pics.
http://*****************/forums/showthread.php?t=1511
saxhouse is offline
Old 07-06-2006, 07:11 PM   #4
My Ride: GLH-T
Ok before i tear my whole wiring harness apart maybe you guys can help. (I hope). My fan is still not working. When I jump 12V to the fan it comes on. So that rules out a bad fan. I jumped a ground and 12V to the relay and it moves up and down. So its not a bad relay. I took the housing off the relay and had everything hooked up and i used my finger to manually push the relay down and the fan came on. So what i figured out is there is a wire not triggering the relay to flip. I think it is the white wire but im not sure.....I also check contiunity between what i think is a diode and there is none. So im not sure if there is suppose to be??
Old 07-07-2006, 01:15 AM   #5
My Ride: GLH-T
has anybody had this problem? im totally stumped i just check all the wires and EVERYSINGLE wire checks out good...
Loans | Gas Suppliers | Loan | Remortgages | Psychic Readings
Page generated in 0.31298 seconds with 13 queries
