Old 07-03-2006, 05:41 PM   #1
Ok, wiring harness swap problem...
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
I have a 94 dodge shadow 3.0 5 speed. I swapped engine harness (TPS, AIS, Fuel, Alternator, O2) and everything plugged in fine except the small 2 plug connector. Well one was the same color and the only difference between the connectors was the inside. So I spliced my old harness plug in and matched the one color and the other. Anyways, it started up and ran, but not soo well. It felt odd. So I took it for a drive and through the entire RPM range, it was inconsistent. I blipped the Throttle and a MIL light came on. The code was a 24, which is TPS signal. Well, I came home and swapped the spare TPS. No difference. Then I bought a new one, and still no difference. I started the car and unplugged the 2 prong connector (behind the battery), and MIL light came on. I checked the code. It was 02 sensor signal. That made me curious. And today I took the loom off the old harness to see where those wires go. One runs to the TPS, then to the O2 sensor. The other runs to the EGR, which my car doesn't have. Both wiring harnesses came off 5 speeds 3.0's, No EGR. I know this for a fact. Anyways, I need input because my car idles crappy now and is not smooth at all in the RPM range, not to mention is running Rich as hell. I posted in the 3.0 section and regretfully recieved no response, which is why I'm posting here. I will take any input and add information if needed. Thanks.
DustyR/T is offline
Old 07-04-2006, 09:22 PM   #2
ok, well either nobody knows what to do w/ this situation, or I just can't get help period.
DustyR/T is offline
Old 07-06-2006, 02:06 PM   #3
ok, my chrysler mech. fixed it. For some reason the Lebaron 3.0 harness differed in the aspect of the TPS power input wire location. So he swapped the wires and soldered it and voila!, it works like a charm. I am extremely happy that she is up and running again, and word to the wise. Even though the two motors are the same, there were multiple variations of the harness and to make absolutely sure that everything looks the same and plugs in the same.
DustyR/T is offline
Mobile Phone deals | Loans | Secured Loans | Loans | Loans
Page generated in 0.30911 seconds with 13 queries
