Old 11-20-2006, 10:07 PM   #1
High Beam Ind. light on with low beams.... loose ground?
My Ride: 1990 Spirit
Engine: 2.5 T1
When I have my low beam headlights lights on, and am driving around. The High beam indicator light comes on very faintly.
What should I be looking for? I tried to see for any loose grounds, and couldn't seem to find any.
- Jim
90Acclaim is offline
Old 11-23-2006, 11:44 PM   #2
My Ride: 92 Iroc R/T Red
Engine: TIII
sounds like one of your grounds in the front is no good. disconect each of your headlight plugs one at a time to see which side you need to fix. If it doesn't go off pulling one at a time pull both and see if that turns it off. The grounds are all run together and just one wire is actually hooked to ground. sometimes the splice is the problem and opening the harness is the way to find it.
Tim
charger R/T is offline
Old 11-24-2006, 12:10 AM   #3
My Ride: 85 GLHT, 87 ShelbyZ
might want to see if the bulb is tight in the back of the cluster
GLHNSLHT2 is offline
Old 11-25-2006, 09:47 AM   #4
Engine: 2.5 T1
Tim
Very good, thanks
- Jim
Word Definitions | Remortgages | Loans | Free Advertising | Credit Cards
Page generated in 0.30464 seconds with 13 queries
