Old 11-27-2006, 10:47 AM   #1
Exclamation I think I broke my SBEC. Did I?
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I have a '93 Shadow ES V6 / 604 car. On saturday, I had some wiring off the engine to fix another problem. When it got dark, I hooked up the battery so the underhood light would work. I wasn't thinking, and had the alternator wiring harness in my hand and accidentally arced it off the alternator. ZAP!!! That will get your attention!
The car still drove fine on sunday.
Today I was going to work and noticd that the alternator gauge seemed to be reading a bit high. I turned on the headlights, and the tach dropped to zero for a second then came back up, the 604 downshifted and then shifted back up, and the temperature gauge dropped. When I turned the lights off, everything went back to normal.
What do I need to do? SBEC replacement? Transmission control module replacement? I can get those computers pretty easily in junkyards around here.
I know the voltage regulator is in the SBEC, so it wouldn't surprise me if that part got blown out.
Anyone else ever do this? What did it take to fix it?
Tim_K is offline
Old 11-27-2006, 02:55 PM   #2
My Ride: 88 DOHC Pacifica
Engine: 2.5L
Images: 14
If your having voltage regulation problems then this is your solution.
http://www.turbododge.com/forums/sho...657#post807657
MachIIIRayzor is offline
Old 11-27-2006, 02:55 PM   #3
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
Maybe going externally for the voltage regulator will help?
How To: External Voltage Regulator w/pics?
I don't know why this is not a sticky in this forum...
dyno sheet
I practice what I preach:
1992 GTC convertible 2.5/568 aluminum fw/Tu 6puck feramic/s60/3in Tu sv/+40S/ FWD CAL /FMIC/self ported head+1mm exh valves/self ported ex mani/stock 2piece w/stock tb/PSSSSTSSSS
crazymadbastard is offline
Mortgages | The Latest Gadgets | Mobile Phone | Mortgage Calculator | Mobile Phone
Page generated in 0.34321 seconds with 13 queries
