07-22-2007, 12:25 AM
ASD Relay Replacement?
New here, but trying to bring a 87 GLHS back to life and need some help.
Car will not start. Coil is not energized (no 12V) and fuel pump does not run (no 12V). Fuel pump fuse is OK.
The signal from the Logic Module to energize the ASD is 12V, but the ASD output is 0V (measured at the fuel pump fuse and at the Power Module Connector). Pulled out the fuel pump fuse, disconnected the coil and fuel injectors, and the the ASD output is still 0V.
Connected 12V to the fuel pump, coil, and fuel injectors and car will start and run fine. Sounds like the ASD relay?
Would rather not buy an entire Power Module (assuming they are $$$) for only a bad ASD relay. I understand that later cars had a separate ASD relay. Is this correct?
Thinking about connecting a separate ASD relay, and looking for ideas. Thanks!
Bill
