07-25-2007, 10:04 PM
Code 41
My Ride: Turbo anything
Engine: 2.2 TI & TII
I know this is not a turbo dodge question, but a dodge question all the same.
My 95 dodge dakota has a code 41 "Alternator field control circuit open or shorted" and keep draining the battery. So I did the engine running and pulled off the battery cable test and the engine stopped. So I believed that to be the altenator. Went and install a brand new altenator and still have the same problem. Engine will stop when I pull off the ground cable, and still draining the battery.
My question is what else could this be..........? Is there some other electrical component that I need to check.....?
On the bright side, the 86 GLHT is running strong.
Thanks guys.
