Old 10-18-2007, 12:56 PM   #1
2-button traveller into Shadow?
My Ride: 92 Shadow
Engine: 2.5 T1
Has anyone done it? Is there a plug for it or does it have to be wired in?
Id like to put one in where the boost gauge is (or the 'message center'). I put a similar type of trip computer in my tbird and it pretty much increased my gas mileage by compelling me to keep the average mpg above 28.
First fillup in the shadow averaged 21mpg calculated at the second fillup. I thought that was pretty decent seeing as it didnt have a tuneup yet, and its still out of alignment. I also pounded on it a bit as well. Im hoping for at least 25mpg by next fillup. Just got a tuneup on it with napa parts, and the front end should be straightened up here soon.
bhazard is offline
Old 10-18-2007, 09:03 PM   #2
Re: 2-button traveller into Shadow?
My Ride: 92 Iroc R/T Red
Engine: TIII
I assume you want to use the 2 button traveler from lebarons for this? Be the first to try it. Here is a link to hook it up.
Wiring a Lebaron Traveler computer
There is an error on the page and have seen a few threads of people getting confused. In the article he says pin 3 is for illumination. well it is. But later when he gets to hooking up the buss lines he says to hook wire number 7 of the body computer to pin 3 he made a mistake and it should read pin 6.
When I wired in my 2 button into my daytona I did find the 2 buss wires on the body computer were twisted together right up to the plug. All buss wires running through the car are twisted to cancel stray signals and keep interferance down. So when I found the 2 it listed and know buss wires are twisted I knew I had the right 2. I also twisted the 2 I ran to my traveler. Good luck and let us know if it works.
Tim
charger R/T is offline
Old 10-19-2007, 01:24 AM   #3
My Ride: 92 Shadow
Engine: 2.5 T1
I could have sworn Ive seen a small trip computer that is about the size of the boost gauge or message center. That one looks like it would take up a whole DIN space.
bhazard is offline
Old 10-19-2007, 10:59 PM   #4
My Ride: 92 Shadow
Engine: 2.5 T1
Wasnt there an overhead console that came in shadows? What did it have?
bhazard is offline
Old 10-21-2007, 11:02 AM   #5
My Ride: 92 Shadow
Engine: 2.5 T1
Anyone? Id like to get some sort of trip computer in this car. Im pretty sure an overhead console wouldnt work on a sunroof car though.
bhazard is offline
Old 10-24-2007, 01:08 AM   #6
My Ride: 92 Shadow
Engine: 2.5 T1
HERE is the one Im talking about. This was posted by someone in the P-body picture thread. Whats it from and how do I make it work?
bhazard is offline
Old 10-24-2007, 01:33 AM   #7
92lebaronGTC's Avatar
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Images: 30
That looks cool! never seen one that small before.
-Steve Reject.
92lebaronGTC is offline
Old 10-24-2007, 01:49 AM   #8
My Ride: 92 Shadow
Engine: 2.5 T1
I sent the guy a PM, hopefully I will get something back!
bhazard is offline
Old 10-24-2007, 02:25 AM   #9
My Ride: 87 daytona shelby z
thats from a 88-89 newyorker... i had one of those in my 88, just left of the steering column..beside the headlight switch. kinda rare though, most newyorkers only had a car graphic there, which showed doors open and stuff, "dummy lights" if you will.. hope that helps!
nechi20 is offline
Old 10-25-2007, 03:25 PM   #10
My Ride: 92 Shadow
Engine: 2.5 T1
I guess Ill have to check the junkyards. I think I read somewhere they started using them in 86.
bhazard is offline
Old 11-02-2007, 06:05 PM   #11
My Ride: '89 Dodge Shadow
Engine: 2.2L TBI
Images: 2
That was my handiwork there...lol. I basically took 2 travelers, a computer cable, and some solder/patience to make it work. It's a straight hardwire job from start to finish, as a traveler was never offered in the P-body cars, just a compass/outside temp in the Oheads. Once I get settled back into my own house, I'll snatch it out and make some better pics of what's involved.
BE WARNED: this project IS NOT for the impatient or those not good with a Dremel tool.
Lone Eagle is offline
Old 11-02-2007, 09:39 PM   #12
My Ride: 92 Shadow
Engine: 2.5 T1
Uh oh...
bhazard is offline
Old 11-04-2007, 05:20 AM   #13
ooohh.. this i gotta see!
nechi20 is offline
Old 02-19-2008, 04:16 PM   #14
My Ride: 94shadow, base
so, any updates on this ? . would really like to see how it was done
135SoHc is offline
Old 02-20-2008, 09:42 AM   #15
My Ride: 92 Chrysler Imperial
Engine: 3.8l V6
Yeah, I only ever see the New Yorker Traveler when the car has the digital dash but the owner decided not to spring for the fancier EVIC system (overhead trip computer). These cars are usually (but not always) missing the Chrysler/Infinity option as well. I try to buy those whenever I find them on yard runs, but I have no spares right now.
I have two '88 New Yorker Landaus. One came with the Traveler, one with EVIC. I added the EVIC to the first car, and a Traveler to the second car. You wouldn't believe how often having two working trip computers comes in handy
Oklahoma Wolf is offline
Remortgages | Secured Loans | Loans | Blog Forum | Loan
Page generated in 0.46887 seconds with 13 queries
